Dell Inspiron 15-3521 Wireless Card Replacement
    1. Dell Inspiron 15-3521 Wireless Card Replacement, Remove the Battery: step 1, image 1 of 3 Dell Inspiron 15-3521 Wireless Card Replacement, Remove the Battery: step 1, image 2 of 3 Dell Inspiron 15-3521 Wireless Card Replacement, Remove the Battery: step 1, image 3 of 3
      • Flip the laptop over.
      • Slide the latches toward the outside of the laptop to unlock the battery.
      • Lift the battery out of the laptop.
      Ask FixBot
    2. Dell Inspiron 15-3521 Wireless Card Replacement, Removing Keyboard: step 2, image 1 of 3 Dell Inspiron 15-3521 Wireless Card Replacement, Removing Keyboard: step 2, image 2 of 3 Dell Inspiron 15-3521 Wireless Card Replacement, Removing Keyboard: step 2, image 3 of 3
      • Flip laptop right side up
      • Using a flat head screwdriver, depress locking tabs holding keyboard into place
      • Using a spudger, pry the keyboard from the laptop, giving room to access with hands.
      • Using hands, remove keyboard completely from laptop body, leaving only the connecting cord that attaches the keyboard to the laptop.
      Ask FixBot
    3. Dell Inspiron 15-3521 Wireless Card Replacement, Disconnecting the Keyboard Cable: step 3, image 1 of 3 Dell Inspiron 15-3521 Wireless Card Replacement, Disconnecting the Keyboard Cable: step 3, image 2 of 3 Dell Inspiron 15-3521 Wireless Card Replacement, Disconnecting the Keyboard Cable: step 3, image 3 of 3
      • To disconnect the keyboard, locate the keyboard cable locking mechanism.
      • Open the locking mechanism by gently pulling up.
      • Slide out the keyboard cable from the interface to separate the keyboard form the laptop.
      Ask FixBot
    1. Dell Inspiron 15-3521 Wireless Card Replacement, Wireless Card Removal: step 4, image 1 of 3 Dell Inspiron 15-3521 Wireless Card Replacement, Wireless Card Removal: step 4, image 2 of 3 Dell Inspiron 15-3521 Wireless Card Replacement, Wireless Card Removal: step 4, image 3 of 3
      • Remove the wireless card cables powering the wireless card
      • Unscrew the wireless card using a PH0 screwdriver.
      • Replace with a new wireless card, reattaching the power cables.
      Ask FixBot
7 other people completed this guide.
Andrew Dippre
2,947 Reputation
7 Guides authored
Clemson, Team 3-1, Benson Fall 2014 Member of Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 Members
108 Guides authored
2 Guide Comments
On an Insperion 15 model 3878, the Wi-Fi adapter wasn't under the keyboard. It was under the inset cover on the bottom.
I reseated the card connection and then Windows could communicate to configure it.
Student4Life - Reply Share
its wlan is right now 2.4ghz. i want to upgrade it to 5ghz. please suggest a solution!
rohit nair - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 54
All Time: 6,968
