Dell Inspiron 15 Optical Drive Replacement
    1. Dell Inspiron 15 Optical Drive Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 15 Optical Drive Replacement, Battery: step 1, image 2 of 2
      • Make sure your laptop is powered off completely and is not connected to the charger.
      • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
      • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
      Ask FixBot
    2. Dell Inspiron 15 Optical Drive Replacement: step 2, image 1 of 1
      • Lift the battery at an angle using your fingertips and remove it from the laptop.
      • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
      Ask FixBot
    1. Dell Inspiron 15 Optical Drive Replacement, Optical Drive: step 3, image 1 of 2 Dell Inspiron 15 Optical Drive Replacement, Optical Drive: step 3, image 2 of 2
      • Remove the 5mm long Phillips #0 screw that is holding the optical drive in place, as pictured.
      • You can now slide the optical disk drive out of the computer.
      • You do not have to remove the base cover or the Hard Drive if you want to remove just the optical drive.
      Ask FixBot
3 other people completed this guide.
Edward Pacheco
852 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 118
All Time: 5,342
