Community-Contributed Guide
Introduction
Go to step 1 ↓In this guide, we will be showing you how to remove and replace the Display Assembly.
Tools
Disconnect the display cable from the connector on the system board.
Make a note of the display cable and Mini-Card antenna cables routing and remove the cables from the routing guides.
Remove the four screws (two on each side) that secure the display assembly to the computer base.
Lift and remove the display assembly out of the computer base.
Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
Route the display cable and Mini-Card antenna cables through the routing guides.
Connect the display cable to the connector on the system board.
