Dell Inspiron 15 Display Assembly Replacement
    1. Dell Inspiron 15 Display Assembly Replacement, Remove the Screws: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer. After working inside your computer, follow the instructions in After working inside your computer.
      • Remove the screws that secure the display hinges to the palm-rest assembly and open the hinges to an angle of 90 degrees.
      Ask FixBot
    2. Dell Inspiron 15 Display Assembly Replacement, Note the Antenna Cable: step 2, image 1 of 1
      • Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
      Ask FixBot
    3. Dell Inspiron 15 Display Assembly Replacement, Noting the Display Cable: step 3, image 1 of 1
      • Note the display cable routing and remove the cable from its routing guides on the palm-rest assembly.
      Ask FixBot
    4. Dell Inspiron 15 Display Assembly Replacement, Open the Assembly: step 4, image 1 of 1
      • Open the palm-rest assembly.
      Ask FixBot
    5. Dell Inspiron 15 Display Assembly Replacement, Lifting the Palm-Rest Assembly: step 5, image 1 of 2 Dell Inspiron 15 Display Assembly Replacement, Lifting the Palm-Rest Assembly: step 5, image 2 of 2
      • Lift the palm-rest assembly at an angle off the display assembly.
      Ask FixBot
    6. Dell Inspiron 15 Display Assembly Replacement, Placing the Display Assembly: step 6, image 1 of 1
      • Place the display assembly on a clean, flat surface.
      Ask FixBot
    7. Dell Inspiron 15 Display Assembly Replacement, Placing the Display Assembly: step 7, image 1 of 1
      • Place the NEW display assembly on the palm-rest assembly.
      Ask FixBot
    8. Dell Inspiron 15 Display Assembly Replacement, Close the Display Hinges: step 8, image 1 of 1
      • Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
      Ask FixBot
    9. Dell Inspiron 15 Display Assembly Replacement, Replace the Screws: step 9, image 1 of 1
      • Replace the screws that secure the display hinges to the palm-rest assembly.
      Ask FixBot
    10. Dell Inspiron 15 Display Assembly Replacement, Route the Display Cable: step 10, image 1 of 1
      • Route the display cable through its routing guides on the palm-rest assembly.
      Ask FixBot
    11. Dell Inspiron 15 Display Assembly Replacement, Routing the Antenna Cables: step 11, image 1 of 1
      • Route the antenna cables through its routing guides on the palm-rest assembly.
      Ask FixBot
      • Close the display and turn the computer over.
      Ask FixBot
Finish Line
2 other people completed this guide.
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
1 Guide Comment
I can't replace the cables on the left side of the lid through the hinge.
Peter Meyer - Reply Share
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 110
All Time: 3,407
