Dell Inspiron 15 7579 RAM (Memory) Replacement
    1. Dell Inspiron 15 7579 RAM (Memory) Replacement, Back Panel: step 1, image 1 of 1
      • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
      Ask FixBot
    2. Dell Inspiron 15 7579 RAM (Memory) Replacement: step 2, image 1 of 2 Dell Inspiron 15 7579 RAM (Memory) Replacement: step 2, image 2 of 2
      • Insert metal spudger into a gap in between the back panel and the back of the screen.
      • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
      Ask FixBot
    1. Dell Inspiron 15 7579 RAM (Memory) Replacement, RAM (Memory): step 3, image 1 of 1
      • Fold protective flaps to the side on the RAM module located in the upper right corner of the laptop.
      Ask FixBot
    2. Dell Inspiron 15 7579 RAM (Memory) Replacement: step 4, image 1 of 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: step 4, image 2 of 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use the tweezers to push the crimping metal away from the chip. The chip will pop up into an angled position.
      • Remove the chip by pulling at the same angle as the chip with the tweezers.
      Ask FixBot
    3. Dell Inspiron 15 7579 RAM (Memory) Replacement: step 5, image 1 of 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: step 5, image 2 of 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: step 5, image 3 of 3
      • Fold the plastic flap over on the other side.
      • As before, pull the fasteners away from the chip with the tweezers.
      • Remove the chip by carefully pulling it out with the tweezers.
      Ask FixBot
    4. Dell Inspiron 15 7579 RAM (Memory) Replacement: step 6, image 1 of 2 Dell Inspiron 15 7579 RAM (Memory) Replacement: step 6, image 2 of 2
      • When reassembling, you must match the notch in the card with the notch in the connector header shown in red.
      • Doing otherwise will break the stick if forced.
      Ask FixBot
Inaki Madrigal
775 Reputation
6 Guides authored
Cal Poly, Team S24-G9, Maness Spring 2018 Member of Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 63
All Time: 1,177
