Dell Inspiron 15 7579 Battery Replacement
    1. Dell Inspiron 15 7579 Battery Replacement, Back Panel: step 1, image 1 of 1
      • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
      Ask FixBot
    2. Dell Inspiron 15 7579 Battery Replacement: step 2, image 1 of 2 Dell Inspiron 15 7579 Battery Replacement: step 2, image 2 of 2
      • Insert metal spudger into a gap in between the back panel and the back of the screen.
      • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
      Ask FixBot
    1. Dell Inspiron 15 7579 Battery Replacement, Battery: step 3, image 1 of 2 Dell Inspiron 15 7579 Battery Replacement, Battery: step 3, image 2 of 2
      • Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
      Ask FixBot
    2. Dell Inspiron 15 7579 Battery Replacement: step 4, image 1 of 1
      • Pull out the fabric clip that attaches the battery to the main board from the connector by hand.
      • Remove the battery from the device.
      Ask FixBot
10 other people completed this guide.
Inaki Madrigal
775 Reputation
6 Guides authored
Cal Poly, Team S24-G9, Maness Spring 2018 Member of Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 Members
72 Guides authored
2 Guide Comments
Thanks! Very helpful and to the point!
You ARE TECHNICALLY missing one step however, removing the fabric ribbon from the old battery at the end. Yes, it seems like common sense but…
Anyways, thanks.
Thomas Keats - Reply Share
Thanks for the help, worked well.
Remember the connector needs to be removed from the old battery and re-installed in the new. I used a small slotted screwdriver.
A. Holness
June 7, 2020
andrew.w.holness - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 70
All Time: 7,796
