Dell Inspiron 15 7579 Back Panel Replacement
    1. Dell Inspiron 15 7579 Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
      Ask FixBot
    2. Dell Inspiron 15 7579 Back Panel Replacement: step 2, image 1 of 2 Dell Inspiron 15 7579 Back Panel Replacement: step 2, image 2 of 2
      • Insert metal spudger into a gap in between the back panel and the back of the screen.
      • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
      Ask FixBot
Inaki Madrigal
775 Reputation
6 Guides authored
Cal Poly, Team S24-G9, Maness Spring 2018 Member of Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 62
All Time: 1,537
