Dell Inspiron 15 7560 Fan Replacement
    1. Dell Inspiron 15 7560 Fan Replacement, Fan: step 1, image 1 of 1
      • Power off the laptop.
      • Place the laptop with the bottom facing upwards.
      • Remove eight 5 mm screws from the bottom of the laptop.
      • Loosen the three captive screws.
      • Use an iFixit opening tool to pry the bottom cover away from the laptop.
      Ask FixBot
    2. Dell Inspiron 15 7560 Fan Replacement: step 2, image 1 of 1
      • Remove the two screws from the fan.
      Ask FixBot
    3. Dell Inspiron 15 7560 Fan Replacement: step 3, image 1 of 2 Dell Inspiron 15 7560 Fan Replacement: step 3, image 2 of 2
      • Remove the black insulating tape from the fan connector.
      • Pinch the sides of the white fan connector with your thumb and index fingernail and pull it out of its socket.
      • Remove the fan from the laptop.
      • Save the insulating tape for reinstallation.
      Ask FixBot
    4. Dell Inspiron 15 7560 Fan Replacement: step 4, image 1 of 2 Dell Inspiron 15 7560 Fan Replacement: step 4, image 2 of 2
      • Place the new fan in the laptop.
      • Plug the cable connector into its socket on the motherboard.
      • Replace the two screws around the fan.
      Ask FixBot
    5. Dell Inspiron 15 7560 Fan Replacement: step 5, image 1 of 1
      • Before replacing the bottom cover, start the computer to check if the cooling fan is installed successfully.
      Ask FixBot
    6. Dell Inspiron 15 7560 Fan Replacement: step 6, image 1 of 1
      • Power down the computer.
      • Reassemble the bottom cover.
      Ask FixBot
Finish Line
Kristen Gismondi
108,497 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
123 Members
79,603 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 45
All Time: 1,412
