Dell Inspiron 15 5584 CPU Thermal Paste Replacement
    1. Dell Inspiron 15 5584 CPU Thermal Paste Replacement, Bottom Cover: step 1, image 1 of 1
      • Make sure to turn off and unplug your laptop before starting.
      • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
      Ask FixBot
    2. Dell Inspiron 15 5584 CPU Thermal Paste Replacement: step 2, image 1 of 3 Dell Inspiron 15 5584 CPU Thermal Paste Replacement: step 2, image 2 of 3 Dell Inspiron 15 5584 CPU Thermal Paste Replacement: step 2, image 3 of 3
      • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
      • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
      • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
      Ask FixBot
    3. Dell Inspiron 15 5584 CPU Thermal Paste Replacement: step 3, image 1 of 2 Dell Inspiron 15 5584 CPU Thermal Paste Replacement: step 3, image 2 of 2
      • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
      • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
      • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
      Ask FixBot
    4. Dell Inspiron 15 5584 CPU Thermal Paste Replacement: step 4, image 1 of 2 Dell Inspiron 15 5584 CPU Thermal Paste Replacement: step 4, image 2 of 2
      • Gently pry off the bottom cover from the laptop.
      • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
      Ask FixBot
    1. Dell Inspiron 15 5584 CPU Thermal Paste Replacement, Battery: step 5, image 1 of 2 Dell Inspiron 15 5584 CPU Thermal Paste Replacement, Battery: step 5, image 2 of 2
      • Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
      • Official iFixit PH000-PH1 Phillips screwdrivers and bits are designed to be compatible with JIS screws, so they are safe to use.
      Ask FixBot
    2. Dell Inspiron 15 5584 CPU Thermal Paste Replacement: step 6, image 1 of 3 Dell Inspiron 15 5584 CPU Thermal Paste Replacement: step 6, image 2 of 3 Dell Inspiron 15 5584 CPU Thermal Paste Replacement: step 6, image 3 of 3
      • Detach the motherboard connector tab from the top left of the battery.
      • Remove the battery from the device.
      • Be sure to carefully wiggle the connector out from the battery socket. Ripping it out too forcefully could damage the socket.
      Ask FixBot
    1. Dell Inspiron 15 5584 CPU Thermal Paste Replacement, CPU Thermal Paste: step 7, image 1 of 3 Dell Inspiron 15 5584 CPU Thermal Paste Replacement, CPU Thermal Paste: step 7, image 2 of 3 Dell Inspiron 15 5584 CPU Thermal Paste Replacement, CPU Thermal Paste: step 7, image 3 of 3
      • Loosen the four captive 3.5 mm screws securing the heat sink to the motherboard using a Phillips #0 screwdriver.
      • Remove the CPU plate cover from the motherboard and safely place it off to the side.
      Ask FixBot
    2. Dell Inspiron 15 5584 CPU Thermal Paste Replacement: step 8, image 1 of 1
      • Place a small amount of rubbing alcohol on either a paper towel or cotton swab.
      • Use the paper towel or cotton swab to completely remove the thermal paste from the CPU.
      • Leave it to dry for around an hour before applying the new thermal paste. You can find thermal paste application instructions here.
      Ask FixBot
Sam Vorn
1,015 Reputation
9 Guides authored
UMass Dartmouth, Team 1-1, Mellen Spring 2022 Member of UMass Dartmouth, Team 1-1, Mellen Spring 2022
UMASSD-MELLEN-S22S1G1
3 Members
118 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 70
All Time: 1,604
