Dell Inspiron 15 5584 Bottom Cover Replacement
    1. Dell Inspiron 15 5584 Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 1
      • Make sure to turn off and unplug your laptop before starting.
      • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
      Ask FixBot
    2. Dell Inspiron 15 5584 Bottom Cover Replacement: step 2, image 1 of 3 Dell Inspiron 15 5584 Bottom Cover Replacement: step 2, image 2 of 3 Dell Inspiron 15 5584 Bottom Cover Replacement: step 2, image 3 of 3
      • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
      • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
      • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
      Ask FixBot
    3. Dell Inspiron 15 5584 Bottom Cover Replacement: step 3, image 1 of 2 Dell Inspiron 15 5584 Bottom Cover Replacement: step 3, image 2 of 2
      • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
      • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
      • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
      Ask FixBot
    4. Dell Inspiron 15 5584 Bottom Cover Replacement: step 4, image 1 of 2 Dell Inspiron 15 5584 Bottom Cover Replacement: step 4, image 2 of 2
      • Gently pry off the bottom cover from the laptop.
      • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
      Ask FixBot
Sam Vorn
1,015 Reputation
9 Guides authored
UMass Dartmouth, Team 1-1, Mellen Spring 2022 Member of UMass Dartmouth, Team 1-1, Mellen Spring 2022
UMASSD-MELLEN-S22S1G1
3 Members
118 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 13
Past 30 Days: 32
All Time: 861
