Dell Inspiron 15 5576 Gaming Display Assembly Replacement
    1. Ask FixBot
    2. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Disconnecting the Display Cable: step 2, image 1 of 1
      • Using the pull tab, disconnect the display cable from the system board.
      Ask FixBot
    3. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Note the Display Cable: step 3, image 1 of 1
      • Note the display-cable routing and remove the cable from the routing guides on the computer base.
      Ask FixBot
    4. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Disconnecting the Antenna Cables: step 4, image 1 of 1
      • Disconnect the antenna cables from the wireless card.
      Ask FixBot
    5. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Note the Antenna Cable Routing: step 5, image 1 of 1
      • Note the antenna-cable routing and remove the antenna cables from the routing guides on the computer base.
      Ask FixBot
    6. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Sliding the Display Cable: step 6, image 1 of 1
      • Slide the display cable and antenna cables through the slots on the computer base.
      Ask FixBot
    7. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Remove the Screws: step 7, image 1 of 1
      • Remove the four screws (M2x5) that secure the display assembly to the computer base.
      Ask FixBot
    8. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Lifting the Display Assembly: step 8, image 1 of 1
      • Lift the display assembly off the computer base.
      Ask FixBot
    9. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Align the Screw Holes: step 9, image 1 of 1
      • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
      Ask FixBot
    10. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Replace the Screws: step 10, image 1 of 1
      • Replace the four screws (M2x5) that secure the display assembly to the computer base.
      Ask FixBot
    11. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Sliding the Display Cable: step 11, image 1 of 1
      • Slide the display cable and antenna cables through the slot on the computer base.
      Ask FixBot
    12. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Route the Display Cable: step 12, image 1 of 1
      • Close the display and turn the computer over.
      • Route the display cable and antenna cables through the routing guides on the computer base.
      Ask FixBot
    13. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Connect the Antenna Cables: step 13, image 1 of 1
      • Connect the antenna cables to the wireless card.
      Ask FixBot
    14. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Connecting the Display Cable: step 14, image 1 of 1
      • Connect the display cable to the system board.
      Ask FixBot
      Ask FixBot
Finish Line
Terrence15
80,125 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,136 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 940
