Dell Inspiron 15 3593 Battery Replacement
    1. Dell Inspiron 15 3593 Battery Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 15 3593 Battery Replacement, Battery: step 1, image 2 of 2
      • First, make sure the computer is turned off and unplugged.
      • Turn the computer upside down so its backside is facing you and place on a flat and clean surface to work.
      • Use a Phillips #0 screwdriver to remove six (M2.5x7mm) screws, three (M2x2mm) screws, and one (M2x4mm) screw.
      • Remove the optical drive.
      Ask FixBot
    2. Dell Inspiron 15 3593 Battery Replacement: step 2, image 1 of 2 Dell Inspiron 15 3593 Battery Replacement: step 2, image 2 of 2
      • Turn the laptop over and open the lid so the screen faces you.
      • Use the plastic opening tool to gently pry the top panel with keyboard off of the computer. Work your way around the perimeter and undo the clips holding it down.
      • Don't use a butter knife like in the photo, as this could cause damage to the device.
      Ask FixBot
    3. Dell Inspiron 15 3593 Battery Replacement: step 3, image 1 of 3 Dell Inspiron 15 3593 Battery Replacement: step 3, image 2 of 3 Dell Inspiron 15 3593 Battery Replacement: step 3, image 3 of 3
      • Close the lid and flip the laptop so the backside is facing up.
      • Pull the back panel off to reveal the battery.
      Ask FixBot
    4. Dell Inspiron 15 3593 Battery Replacement: step 4, image 1 of 2 Dell Inspiron 15 3593 Battery Replacement: step 4, image 2 of 2
      • Disconnect the battery connector from the motherboard.
      • Use the Phillips #0 screwdriver to remove the four (M2x3mm) screws that are keeping the battery in place.
      Ask FixBot
    5. Dell Inspiron 15 3593 Battery Replacement: step 5, image 1 of 1
      • Lift the battery out carefully and put the new battery in.
      Ask FixBot
Reassemble the computer by following
the above steps in reversed order.
4 other people completed this guide.
Abdul Obaid
211 Reputation
1 Guide authored
2 Guide Comments
not all of the steps
there is somethings missing
aaaa2020 - Reply Share
So where is the rest of the story?
Jeanette Martinez - Reply Share
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 98
All Time: 5,016
