Dell Inspiron 15 3568 Hard Drive Replacement
    1. Dell Inspiron 15 3568 Hard Drive Replacement, Remove the Screws: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
      • Remove the screws that secure the hard-drive assembly to the computer base.
      Ask FixBot
    2. Dell Inspiron 15 3568 Hard Drive Replacement, Lifting the Latch: step 2, image 1 of 2 Dell Inspiron 15 3568 Hard Drive Replacement, Lifting the Latch: step 2, image 2 of 2
      • Lift the latch and disconnect the hard-drive cable from the system board.
      Ask FixBot
    3. Dell Inspiron 15 3568 Hard Drive Replacement, Lifting the Hard-Drive Assembly: step 3, image 1 of 1
      • Lift the hard-drive assembly off the computer base.
      Ask FixBot
    4. Dell Inspiron 15 3568 Hard Drive Replacement, Disconnecting the Interposer: step 4, image 1 of 1
      • Disconnect the interposer from the hard drive.
      Ask FixBot
    5. Dell Inspiron 15 3568 Hard Drive Replacement, Remove the Screws: step 5, image 1 of 1
      • Remove the screws that secure the hard-drive bracket to the hard drive and lift the hard-drive bracket off the hard drive.
      Ask FixBot
    6. Dell Inspiron 15 3568 Hard Drive Replacement, Placing the Hard-Drive Bracket: step 6, image 1 of 1
      • Place the hard-drive bracket over the NEW hard drive and align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
      Ask FixBot
    7. Dell Inspiron 15 3568 Hard Drive Replacement, Replace the Screws: step 7, image 1 of 1
      • Replace the screws that secure the hard-drive bracket to the hard drive.
      Ask FixBot
    8. Dell Inspiron 15 3568 Hard Drive Replacement, Sliding the Hard-Drive Assembly: step 8, image 1 of 1
      • Slide the hard-drive assembly in the computer base and align the screw holes on the hard-drive assembly with the screw holes on the computer base.
      Ask FixBot
    9. Dell Inspiron 15 3568 Hard Drive Replacement, Slide the Hard-Drive Cable: step 9, image 1 of 2 Dell Inspiron 15 3568 Hard Drive Replacement, Slide the Hard-Drive Cable: step 9, image 2 of 2
      • Slide the hard-drive cable into its connector and close the latch to secure the cable.
      Ask FixBot
    10. Dell Inspiron 15 3568 Hard Drive Replacement, Replace the Screws: step 10, image 1 of 1
      • Replace the screws that secure the hard-drive assembly to the computer base.
      Ask FixBot
Finish Line
Terrence15
80,125 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,153 Guides authored
1 Guide Comment
SSD slot is available or not ? thank you
mbu Shrestha - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 29
All Time: 1,089
