Dell Inspiron 15 3568 Display Assembly Replacement
    1. Dell Inspiron 15 3568 Display Assembly Replacement, Open the Display: step 1, image 1 of 1
      Ask FixBot
    2. Dell Inspiron 15 3568 Display Assembly Replacement, Note the Antenna Cable: step 2, image 1 of 1
      • Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base.
      Ask FixBot
    3. Dell Inspiron 15 3568 Display Assembly Replacement, Remove the Cable: step 3, image 1 of 1
      • Note the display cable routing and remove the cable from its routing guides on the computer base.
      Ask FixBot
    4. Dell Inspiron 15 3568 Display Assembly Replacement, Remove the Screws: step 4, image 1 of 1
      • Remove the screws that secure the display hinges to the computer base.
      Ask FixBot
    5. Dell Inspiron 15 3568 Display Assembly Replacement, Lifting the Display Assembly: step 5, image 1 of 1
      • Carefully lift the display assembly off the computer base.
      Ask FixBot
    6. Dell Inspiron 15 3568 Display Assembly Replacement, Align the Screw Holes: step 6, image 1 of 1
      • Align the screw holes on the display hinges with the screw holes on the computer base.
      Ask FixBot
    7. Dell Inspiron 15 3568 Display Assembly Replacement, Replace the Screws: step 7, image 1 of 1
      • Replace the screws that secure the display hinges to the computer base.
      Ask FixBot
    8. Dell Inspiron 15 3568 Display Assembly Replacement, Route the Display Cable: step 8, image 1 of 1
      • Route the display cable through its routing guides on the computer base.
      Ask FixBot
    9. Dell Inspiron 15 3568 Display Assembly Replacement, Routing the Antenna Cables: step 9, image 1 of 1
      • Route the antenna cables through its routing guides and slide the antenna cables through the slot on the computer base.
      Ask FixBot
      • Close the display and turn the computer over.
      Ask FixBot
Finish Line
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 70
All Time: 955
