Dell Inspiron 15 3567 Hard Drive Replacement
    1. Dell Inspiron 15 3567 Hard Drive Replacement, Open the Latch: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
      • Open the latch and disconnect the hard-drive cable from the system board.
      Ask FixBot
    2. Dell Inspiron 15 3567 Hard Drive Replacement, Remove the Screws: step 2, image 1 of 1
      • Remove the four screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
      Ask FixBot
    3. Dell Inspiron 15 3567 Hard Drive Replacement, Lifting the Hard-Drive Assembly: step 3, image 1 of 1
      • Lift the hard-drive assembly off the palm-rest assembly.
      Ask FixBot
    4. Dell Inspiron 15 3567 Hard Drive Replacement, Disconnect the Interposer: step 4, image 1 of 1
      • Disconnect the interposer from the hard-drive assembly.
      Ask FixBot
    5. Dell Inspiron 15 3567 Hard Drive Replacement, Remove the Screws: step 5, image 1 of 1
      • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
      Ask FixBot
    6. Dell Inspiron 15 3567 Hard Drive Replacement, Lifting the Hard Drive: step 6, image 1 of 1
      • Lift the hard drive off the hard-drive bracket.
      Ask FixBot
    7. Dell Inspiron 15 3567 Hard Drive Replacement, Align the Screw Holes: step 7, image 1 of 1
      • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
      Ask FixBot
    8. Dell Inspiron 15 3567 Hard Drive Replacement, Replace the Screws: step 8, image 1 of 1
      • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
      Ask FixBot
    9. Dell Inspiron 15 3567 Hard Drive Replacement, Connect the Interposer: step 9, image 1 of 1
      • Connect the interposer to the hard drive.
      Ask FixBot
    10. Dell Inspiron 15 3567 Hard Drive Replacement, Placing the Hard-Drive Assembly: step 10, image 1 of 1
      • Place the hard-drive assembly in the palm-rest assembly and align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly.
      Ask FixBot
    11. Dell Inspiron 15 3567 Hard Drive Replacement, Replace the Screws: step 11, image 1 of 1
      • Replace the four screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
      Ask FixBot
    12. Dell Inspiron 15 3567 Hard Drive Replacement, Sliding the Hard Drive Cable: step 12, image 1 of 1
      • Slide the hard-drive cable into its connector on the system board and close the latch to secure the cable.
      Ask FixBot
Finish Line
4 other people completed this guide.
Terrence15
80,125 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,154 Guides authored
5 Guide Comments
My Dell Inspiron 15 3567 has a bottom cover which I STRONGLY suggest be removed after REMOVING THE BATTERY.
IMHO Those are important steps - their omission makes me lose any credibility for your site.
[deleted] - Reply Share
The steps that need to be PRIOR to this guide are to remove the keyboard first, disconnect the keyboard cable, remove the 5 screws under the keyboard attaching the plastic to the motherboard. Then turn over the laptop, remove some 12 screws or so, remove the battery, remove the DVD drive, then separate the bottom case from the rest of the laptop carefully.
Thomas Dillon - Reply Share
This guide is utterly useless and it neglects all the steps to get the actual bottom cover off to access the hard drive assembly. Zero stars.
pamadeus - Reply Share
This guide is totally incomplete. It doesn't show how to access the drive in the first place. This guide should be taken down.
DarkAthena - Reply Share
This guide is useless. I condemn the author for posting such an incomplete guide.
Scyth3934 - Reply Share
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 87
All Time: 13,544
