Dell Inspiron 15 3567 Display Assembly Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
90
All Time:
3,701
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 35 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Display Assembly.
Tools
    1. Dell Inspiron 15 3567 Display Assembly Replacement, Remove the Screws: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Remove the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
      Ask FixBot
    2. Dell Inspiron 15 3567 Display Assembly Replacement, Open the Display Hinges: step 2, image 1 of 1
      • Open the display hinges to an angle of 90 degrees.
      Ask FixBot
    3. Dell Inspiron 15 3567 Display Assembly Replacement, Peel the Tape: step 3, image 1 of 1
      • Peel the tape that secures the display cable to the palm-rest assembly.
      Ask FixBot
    4. Dell Inspiron 15 3567 Display Assembly Replacement, Open the Latch: step 4, image 1 of 1
      • Open the latch and disconnect the display cable.
      Ask FixBot
    5. Dell Inspiron 15 3567 Display Assembly Replacement, Note the Display Cable: step 5, image 1 of 1
      • Note the display cable routing and remove the display cable from the routing guides on the palm-rest assembly.
      Ask FixBot
    6. Dell Inspiron 15 3567 Display Assembly Replacement, Note the Antenna Cable: step 6, image 1 of 1
      • Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
      Ask FixBot
    7. Dell Inspiron 15 3567 Display Assembly Replacement, Open the Palm Rest Assembly: step 7, image 1 of 1
      • Open the palm-rest assembly at an angle and slide it off the display assembly.
      Ask FixBot
    8. Dell Inspiron 15 3567 Display Assembly Replacement, Placing the Display Assembly: step 8, image 1 of 1
      • Place the NEW display assembly on a clean, flat surface.
      Ask FixBot
    9. Dell Inspiron 15 3567 Display Assembly Replacement, Placing the Palm-Rest Assembly: step 9, image 1 of 1
      • Place the palm-rest assembly on the display assembly.
      Ask FixBot
    10. Dell Inspiron 15 3567 Display Assembly Replacement, Close the Display Hinges: step 10, image 1 of 1
      • Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
      Ask FixBot
    11. Dell Inspiron 15 3567 Display Assembly Replacement, Replace the Screws: step 11, image 1 of 1
      • Replace the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
      Ask FixBot
    12. Dell Inspiron 15 3567 Display Assembly Replacement, Route the Antenna Cables: step 12, image 1 of 1
      • Route the antenna cables through the routing guides on the palm-rest assembly.
      Ask FixBot
    13. Dell Inspiron 15 3567 Display Assembly Replacement, Connecting the Display Cable: step 13, image 1 of 1
      • Connect the display cable and close the latch to secure the cable.
      Ask FixBot
    14. Dell Inspiron 15 3567 Display Assembly Replacement, Route the Display Cable: step 14, image 1 of 1
      • Route the display cable through the routing guides on the palm-rest assembly.
      Ask FixBot
    15. Dell Inspiron 15 3567 Display Assembly Replacement, Adhere the Tape: step 15, image 1 of 1
      • Adhere the tape that secures the display cable to the palm-rest assembly.
      Ask FixBot
      • Close the display and turn the computer over.
      Ask FixBot
Finish Line
3 other people completed this guide.
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 90
All Time: 3,701
