Up to 20% off select tools
Dell Inspiron 15 3559 Memory Module Replacement
Views: 1K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
51
All Time:
1,044
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 50 seconds
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Hard Drive.
    1. Dell Inspiron 15 3559 Memory Module Replacement, Popping up the Memory Module: step 1, image 1 of 2 Dell Inspiron 15 3559 Memory Module Replacement, Popping up the Memory Module: step 1, image 2 of 2
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Using your fingertips, pry apart the securing clips on each end of the memory-module slot until the memory module pops up.
      Ask FixBot
    2. Dell Inspiron 15 3559 Memory Module Replacement, Removing the Memory Module: step 2, image 1 of 1
      • Slide and remove the memory module from the memory-module slot.
      Ask FixBot
    3. Dell Inspiron 15 3559 Memory Module Replacement, Align the Notch: step 3, image 1 of 2 Dell Inspiron 15 3559 Memory Module Replacement, Align the Notch: step 3, image 2 of 2
      • Align the notch on the NEW memory module with the tab on the memory-module slot.
      Ask FixBot
    4. Dell Inspiron 15 3559 Memory Module Replacement, Sliding the Memory Module: step 4, image 1 of 1
      • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
      • NOTE: If you do not hear the click, remove the memory module and reinstall it.
      Ask FixBot
Finish Line
Author
with
Terrence15
80,173 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 51
All Time: 1,044
