Dell Inspiron 14z-5423 RAM Replacement
    1. Dell Inspiron 14z-5423 RAM Replacement, RAM: step 1, image 1 of 2 Dell Inspiron 14z-5423 RAM Replacement, RAM: step 1, image 2 of 2
      • Close the display and turn over the computer.
      • Make sure your device is powered down and unplugged before beginning the replacement.
      Ask FixBot
    2. Dell Inspiron 14z-5423 RAM Replacement: step 2, image 1 of 1
      • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
      Ask FixBot
    3. Dell Inspiron 14z-5423 RAM Replacement: step 3, image 1 of 2 Dell Inspiron 14z-5423 RAM Replacement: step 3, image 2 of 2
      • Lightly lift the RAM cover up and at an angle, away from the computer.
      Ask FixBot
    4. Dell Inspiron 14z-5423 RAM Replacement: step 4, image 1 of 2 Dell Inspiron 14z-5423 RAM Replacement: step 4, image 2 of 2
      • Use your fingers to carefully pull the securing clips on the RAM away from each other.
      • The RAM should pop up when the clips are released.
      Ask FixBot
    5. Dell Inspiron 14z-5423 RAM Replacement: step 5, image 1 of 2 Dell Inspiron 14z-5423 RAM Replacement: step 5, image 2 of 2
      • Remove the popped up RAM by pulling it away from the connection.
      • If it does not pop up pry it out in a steady and straight direction.
      Ask FixBot
Brittany
938 Reputation
4 Guides authored
CSU Fullerton, Team 2-2, Bruce Fall 2016 Member of CSU Fullerton, Team 2-2, Bruce Fall 2016
CSUF-BRUCE-F16S2G2
5 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 107
All Time: 952
