Dell Inspiron 14z-5423 Keyboard Replacement
Views: 2K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
102
All Time:
2,043
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
You will need to purchase a keyboard in order to proceed with the replacement.
Tools
  • Spudger
    4.9
    1. Dell Inspiron 14z-5423 Keyboard Replacement, RAM: step 1, image 1 of 2 Dell Inspiron 14z-5423 Keyboard Replacement, RAM: step 1, image 2 of 2
      • Close the display and turn over the computer.
      • Make sure your device is powered down and unplugged before beginning the replacement.
      Ask FixBot
    2. Dell Inspiron 14z-5423 Keyboard Replacement: step 2, image 1 of 1
      • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
      Ask FixBot
    3. Dell Inspiron 14z-5423 Keyboard Replacement: step 3, image 1 of 2 Dell Inspiron 14z-5423 Keyboard Replacement: step 3, image 2 of 2
      • Lightly lift the RAM cover up and at an angle, away from the computer.
      Ask FixBot
    4. Dell Inspiron 14z-5423 Keyboard Replacement: step 4, image 1 of 2 Dell Inspiron 14z-5423 Keyboard Replacement: step 4, image 2 of 2
      • Use your fingers to carefully pull the securing clips on the RAM away from each other.
      • The RAM should pop up when the clips are released.
      Ask FixBot
    5. Dell Inspiron 14z-5423 Keyboard Replacement: step 5, image 1 of 2 Dell Inspiron 14z-5423 Keyboard Replacement: step 5, image 2 of 2
      • Remove the popped up RAM by pulling it away from the connection.
      • If it does not pop up pry it out in a steady and straight direction.
      Ask FixBot
    1. Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: step 6, image 1 of 3 Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: step 6, image 2 of 3 Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: step 6, image 3 of 3
      • Lift the plastic yellow flap on the system board.
      • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
      Ask FixBot
    2. Dell Inspiron 14z-5423 Keyboard Replacement: step 7, image 1 of 1
      • Flip over the computer and open the display.
      Ask FixBot
    3. Dell Inspiron 14z-5423 Keyboard Replacement: step 8, image 1 of 2 Dell Inspiron 14z-5423 Keyboard Replacement: step 8, image 2 of 2
      • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
      • Lift the keyboard off of the computer.
      • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
      Ask FixBot
    4. Dell Inspiron 14z-5423 Keyboard Replacement: step 9, image 1 of 2 Dell Inspiron 14z-5423 Keyboard Replacement: step 9, image 2 of 2
      • Flip the keyboard over onto the palm-rest assembly.
      Ask FixBot
    5. Dell Inspiron 14z-5423 Keyboard Replacement: step 10, image 1 of 3 Dell Inspiron 14z-5423 Keyboard Replacement: step 10, image 2 of 3 Dell Inspiron 14z-5423 Keyboard Replacement: step 10, image 3 of 3
      • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
      Ask FixBot
2 other people completed this guide.
Marisol
626 Reputation
4 Guides authored
CSU Fullerton, Team 2-2, Bruce Fall 2016 Member of CSU Fullerton, Team 2-2, Bruce Fall 2016
CSUF-BRUCE-F16S2G2
5 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 102
All Time: 2,043
