Dell Inspiron 14z-5423 Fan Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
98
All Time:
2,159
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 55 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The fan in this laptop prevents the computer from overheating. It provides good airflow into the computer and out through the vents. Any clogging or damage could cause other problems in your computer.
Tools
    1. Dell Inspiron 14z-5423 Fan  Replacement, RAM: step 1, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement, RAM: step 1, image 2 of 2
      • Close the display and turn over the computer.
      • Make sure your device is powered down and unplugged before beginning the replacement.
      Ask FixBot
    2. Dell Inspiron 14z-5423 Fan  Replacement: step 2, image 1 of 1
      • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
      Ask FixBot
    3. Dell Inspiron 14z-5423 Fan  Replacement: step 3, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement: step 3, image 2 of 2
      • Lightly lift the RAM cover up and at an angle, away from the computer.
      Ask FixBot
    4. Dell Inspiron 14z-5423 Fan  Replacement: step 4, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement: step 4, image 2 of 2
      • Use your fingers to carefully pull the securing clips on the RAM away from each other.
      • The RAM should pop up when the clips are released.
      Ask FixBot
    5. Dell Inspiron 14z-5423 Fan  Replacement: step 5, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement: step 5, image 2 of 2
      • Remove the popped up RAM by pulling it away from the connection.
      • If it does not pop up pry it out in a steady and straight direction.
      Ask FixBot
    1. Dell Inspiron 14z-5423 Fan  Replacement, Optical Drive: step 6, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement, Optical Drive: step 6, image 2 of 2
      • Slide the CD/DVD drive on the side of the laptop out using your fingers.
      • Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
      • You only need to unscrew this screw if you are using this as a prerequisite guide.
      Ask FixBot
    1. Dell Inspiron 14z-5423 Fan  Replacement, Keyboard: step 7, image 1 of 3 Dell Inspiron 14z-5423 Fan  Replacement, Keyboard: step 7, image 2 of 3 Dell Inspiron 14z-5423 Fan  Replacement, Keyboard: step 7, image 3 of 3
      • Lift the plastic yellow flap on the system board.
      • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
      Ask FixBot
    2. Dell Inspiron 14z-5423 Fan  Replacement: step 8, image 1 of 1
      • Flip over the computer and open the display.
      Ask FixBot
    3. Dell Inspiron 14z-5423 Fan  Replacement: step 9, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement: step 9, image 2 of 2
      • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
      • Lift the keyboard off of the computer.
      • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
      Ask FixBot
    4. Dell Inspiron 14z-5423 Fan  Replacement: step 10, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement: step 10, image 2 of 2
      • Flip the keyboard over onto the palm-rest assembly.
      Ask FixBot
    5. Dell Inspiron 14z-5423 Fan  Replacement: step 11, image 1 of 3 Dell Inspiron 14z-5423 Fan  Replacement: step 11, image 2 of 3 Dell Inspiron 14z-5423 Fan  Replacement: step 11, image 3 of 3
      • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
      Ask FixBot
    1. Dell Inspiron 14z-5423 Fan  Replacement, Palm Rest Assembly: step 12, image 1 of 1
      Ask FixBot
    2. Dell Inspiron 14z-5423 Fan  Replacement: step 13, image 1 of 3 Dell Inspiron 14z-5423 Fan  Replacement: step 13, image 2 of 3 Dell Inspiron 14z-5423 Fan  Replacement: step 13, image 3 of 3
      Tool used on this step:
      Buy
      • Remove all 7 rubber screw caps with tweezers.
      • Use a J0 Bit tipped screwdriver unscrew the seven 6 mm Phillips screws on the back casing of the laptop.
      Ask FixBot
    3. Dell Inspiron 14z-5423 Fan  Replacement: step 14, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement: step 14, image 2 of 2
      • Flip the computer over and open the display.
      • Pull on the blue tabs to disconnect the palm rest assembly from the computer.
      Ask FixBot
    4. Dell Inspiron 14z-5423 Fan  Replacement: step 15, image 1 of 1
      • Use J0 Bit screwdriver to remove all four 6 mm Phillips screws.
      Ask FixBot
    5. Dell Inspiron 14z-5423 Fan  Replacement: step 16, image 1 of 3 Dell Inspiron 14z-5423 Fan  Replacement: step 16, image 2 of 3 Dell Inspiron 14z-5423 Fan  Replacement: step 16, image 3 of 3
      • Gently wedge the nylon spudger underneath the palm-rest assembly to release the latches.
      • Continue this process on all sides of the computer edges until the assembly pulls off.
      • Remove the palm rest assembly.
      • If you have difficulty lifting up the assembly, you might not have taken out all 7 screws on the bottom of the computer.
      Ask FixBot
    1. Dell Inspiron 14z-5423 Fan  Replacement, Battery: step 17, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement, Battery: step 17, image 2 of 2
      • Use a J0 Bit screwdriver to remove the two 6 mm Phillips screws securing the battery located near the bottom of the laptop.
      Ask FixBot
    2. Dell Inspiron 14z-5423 Fan  Replacement: step 18, image 1 of 3 Dell Inspiron 14z-5423 Fan  Replacement: step 18, image 2 of 3 Dell Inspiron 14z-5423 Fan  Replacement: step 18, image 3 of 3
      • Lift the tiny black tab and pull the battery out at a slight angle.
      Ask FixBot
    1. Dell Inspiron 14z-5423 Fan  Replacement, Hard Drive: step 19, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement, Hard Drive: step 19, image 2 of 2
      • Lift up the bottom of the hard drive which is located at the bottom of the laptop.
      • Gently pull the drive out at an angle using your fingers.
      Ask FixBot
    2. Dell Inspiron 14z-5423 Fan  Replacement: step 20, image 1 of 1
      • Using a J0 bit tipped screwdriver, remove the four 3 mm black screws on both sides of the hard drive bracket.
      Ask FixBot
    3. Dell Inspiron 14z-5423 Fan  Replacement: step 21, image 1 of 1
      • Slide the hard drive out of the bracket.
      Ask FixBot
    1. Dell Inspiron 14z-5423 Fan  Replacement, Wireless Mini Card: step 22, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement, Wireless Mini Card: step 22, image 2 of 2
      • Locate the wireless mini card at the top of the laptop.
      • It is next to the place where the optics drive used to be.
      Ask FixBot
    2. Dell Inspiron 14z-5423 Fan  Replacement: step 23, image 1 of 1
      • Using a J0 tipped screwdriver, remove the 4 mm Phillips head screw.
      Ask FixBot
    3. Dell Inspiron 14z-5423 Fan  Replacement: step 24, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement: step 24, image 2 of 2
      • Gently, unlatch the black and white wires from the wireless mini card.
      Ask FixBot
    4. Dell Inspiron 14z-5423 Fan  Replacement: step 25, image 1 of 1
      • At an angle, slide out the wireless mini card.
      Ask FixBot
    1. Dell Inspiron 14z-5423 Fan  Replacement, Motherboard: step 26, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement, Motherboard: step 26, image 2 of 2
      • Gently pull the the blue ribbon upwards to disconnect the computer from the motherboard.
      Ask FixBot
    2. Dell Inspiron 14z-5423 Fan  Replacement: step 27, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement: step 27, image 2 of 2
      • Using a plastic opening tool, gently detach the coin cell battery from the foam glue.
      • The coin cell battery is underneath the optical drive.
      Ask FixBot
    3. Dell Inspiron 14z-5423 Fan  Replacement: step 28, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement: step 28, image 2 of 2
      • Using a J0 tipped screwdriver remove the 6 mm Phillips head screw located at the center of the laptop on the motherboard.
      Ask FixBot
    4. Dell Inspiron 14z-5423 Fan  Replacement: step 29, image 1 of 1
      • Remove motherboard at an upward angle.
      • The coin cell battery and fan will be removed with the motherboard.
      Ask FixBot
    1. Dell Inspiron 14z-5423 Fan  Replacement, Fan: step 30, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement, Fan: step 30, image 2 of 2
      • Flip the motherboard over.
      • Locate the red and yellow wires attached to the fan and gently detach them from the motherboard.
      Ask FixBot
    2. Dell Inspiron 14z-5423 Fan  Replacement: step 31, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement: step 31, image 2 of 2
      • Using a J0 tipped screwdriver remove the three 5 mm Phillips head screws that attach fan to the motherboard.
      • The fan base is labeled 1, 2, 3. Make sure you unscrew the screws in this order.
      • The screws are attached to the fan and will fully unscrew.
      Ask FixBot
    3. Dell Inspiron 14z-5423 Fan  Replacement: step 32, image 1 of 2 Dell Inspiron 14z-5423 Fan  Replacement: step 32, image 2 of 2
      • Remove the fan from the motherboard by lifting upwards.
      Ask FixBot
3 other people completed this guide.
john
218 Reputation
1 Guide authored
CSU Fullerton, Team 2-2, Bruce Fall 2016 Member of CSU Fullerton, Team 2-2, Bruce Fall 2016
CSUF-BRUCE-F16S2G2
5 Members
132 Guides authored
2 Guide Comments
Hurrah, just used these instructions to replace my fan and have a beautifully silent working laptop again - thanks! I skipped steps 20-23, and it would have been useful to have a mention that thermal compound was necessary to make a good connection when replacing the heat sink - but all in all great clear instructions. One happy good-as-new laptop owner!
Tanya Cowan - Reply Share
This guide was bloody marvellous! This was the first time I’ve opened a laptop by myself and it was quite a ride but a fun one the only struggle that I had was the bloody blue ribbon connecting to the motherboard other than that the rest was really easy to follow. Thank you so much for the guide and I hope I can some day be a contributor just as great as you random internet person ^^
waluilli - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 98
All Time: 2,159
