Dell Inspiron 14z-5423 Palm Rest Assembly Replacement
    1. Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement, RAM: step 1, image 1 of 2 Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement, RAM: step 1, image 2 of 2
      • Close the display and turn over the computer.
      • Make sure your device is powered down and unplugged before beginning the replacement.
      Ask FixBot
    2. Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 2, image 1 of 1
      • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
      Ask FixBot
    3. Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 3, image 1 of 2 Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 3, image 2 of 2
      • Lightly lift the RAM cover up and at an angle, away from the computer.
      Ask FixBot
    4. Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 4, image 1 of 2 Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 4, image 2 of 2
      • Use your fingers to carefully pull the securing clips on the RAM away from each other.
      • The RAM should pop up when the clips are released.
      Ask FixBot
    5. Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 5, image 1 of 2 Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 5, image 2 of 2
      • Remove the popped up RAM by pulling it away from the connection.
      • If it does not pop up pry it out in a steady and straight direction.
      Ask FixBot
    1. Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement, Optical Drive: step 6, image 1 of 2 Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement, Optical Drive: step 6, image 2 of 2
      • Slide the CD/DVD drive on the side of the laptop out using your fingers.
      • Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
      • You only need to unscrew this screw if you are using this as a prerequisite guide.
      Ask FixBot
    1. Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement, Keyboard: step 7, image 1 of 3 Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement, Keyboard: step 7, image 2 of 3 Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement, Keyboard: step 7, image 3 of 3
      • Lift the plastic yellow flap on the system board.
      • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
      Ask FixBot
    2. Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 8, image 1 of 1
      • Flip over the computer and open the display.
      Ask FixBot
    3. Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 9, image 1 of 2 Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 9, image 2 of 2
      • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
      • Lift the keyboard off of the computer.
      • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
      Ask FixBot
    4. Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 10, image 1 of 2 Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 10, image 2 of 2
      • Flip the keyboard over onto the palm-rest assembly.
      Ask FixBot
    5. Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 11, image 1 of 3 Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 11, image 2 of 3 Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 11, image 3 of 3
      • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
      Ask FixBot
    1. Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement, Palm Rest Assembly: step 12, image 1 of 1
      Ask FixBot
    2. Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 13, image 1 of 3 Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 13, image 2 of 3 Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 13, image 3 of 3
      Tool used on this step:
      Buy
      • Remove all 7 rubber screw caps with tweezers.
      • Use a J0 Bit tipped screwdriver unscrew the seven 6 mm Phillips screws on the back casing of the laptop.
      Ask FixBot
    3. Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 14, image 1 of 2 Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 14, image 2 of 2
      • Flip the computer over and open the display.
      • Pull on the blue tabs to disconnect the palm rest assembly from the computer.
      Ask FixBot
    4. Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 15, image 1 of 1
      • Use J0 Bit screwdriver to remove all four 6 mm Phillips screws.
      Ask FixBot
    5. Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 16, image 1 of 3 Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 16, image 2 of 3 Dell Inspiron 14z-5423  Palm Rest  Assembly Replacement: step 16, image 3 of 3
      • Gently wedge the nylon spudger underneath the palm-rest assembly to release the latches.
      • Continue this process on all sides of the computer edges until the assembly pulls off.
      • Remove the palm rest assembly.
      • If you have difficulty lifting up the assembly, you might not have taken out all 7 screws on the bottom of the computer.
      Ask FixBot
Cynthia Leng
101 Reputation
1 Guide authored
CSU Fullerton, Team 2-2, Bruce Fall 2016 Member of CSU Fullerton, Team 2-2, Bruce Fall 2016
CSUF-BRUCE-F16S2G2
5 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 99
All Time: 1,226
