Dell Inspiron 14R-5421 RAM Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
64
All Time:
793
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to replace the RAM module. RAM improves the performance of your computer and is necessary for a faster and more efficient CPU. This repair can help resolve performance and memory issues for this laptop.
Tools
    1. Dell Inspiron 14R-5421 RAM Replacement, Battery: step 1, image 1 of 1
      • Push the two sliders away from the battery towards the outer edges.
      Ask FixBot
    2. Dell Inspiron 14R-5421 RAM Replacement: step 2, image 1 of 2 Dell Inspiron 14R-5421 RAM Replacement: step 2, image 2 of 2
      • Remove the battery when it pops up.
      Ask FixBot
    1. Dell Inspiron 14R-5421 RAM Replacement, RAM: step 3, image 1 of 1
      • Unscrew the cover from the laptop using a Phillips #0 screwdriver.
      • Remove the cover hiding the internal components by sliding it down.
      Ask FixBot
    2. Dell Inspiron 14R-5421 RAM Replacement: step 4, image 1 of 1
      • Lift the ram module up then pull it out of its slot.
      • Be sure to place the new ram module back into the same slot. Only put a module into slot DIMM B if you have a second working module you want to use.
      Ask FixBot
Jared paiva
504 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 64
All Time: 793
