Dell Inspiron 14R SE 7420 Display Assembly Replacement
    1. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Close the Display: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
      • Close the display and turn the computer over.
      Ask FixBot
    2. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Remove the Screws: step 2, image 1 of 1
      • Remove the screws that secure the display assembly to the computer base.
      Ask FixBot
    3. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Open the Display: step 3, image 1 of 1
      • Turn the computer over and open the display as far as possible.
      Ask FixBot
    4. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Disconnecting the Antenna Cables: step 4, image 1 of 1
      • Disconnect the antenna cables from the connectors on the Mini-Card.
      Ask FixBot
    5. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Remove the Screws: step 5, image 1 of 1
      Ask FixBot
    6. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Lifting the Display Assembly: step 6, image 1 of 1
      • Lift the display assembly off the computer base.
      Ask FixBot
    7. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Placing the Display Assembly: step 7, image 1 of 2 Dell Inspiron 14R SE 7420 Display Assembly Replacement, Placing the Display Assembly: step 7, image 2 of 2
      • Place the display assembly in position and replace the screws that secure the display assembly to the computer base.
      Ask FixBot
    8. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Connecting the Antenna Cables: step 8, image 1 of 1
      • Connect the antenna cables to the connectors on the Mini-Card.
      Ask FixBot
    9. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Close the Display: step 9, image 1 of 1
      Ask FixBot
    10. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Replace the Screws: step 10, image 1 of 1
      • Replace the screws that secure the display assembly to the computer base.
      Ask FixBot
Finish Line
Terrence15
80,125 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,136 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 27
All Time: 676
