Dell Inspiron 14R Display Assembly Replacement
    1. Dell Inspiron 14R Display Assembly Replacement, Remove the Screws: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • Remove the two screws from the computer base.
      Ask FixBot
    2. Dell Inspiron 14R Display Assembly Replacement, Loosen the Cable: step 2, image 1 of 1
      • Loosen the display cable grounding screw.
      Ask FixBot
    3. Dell Inspiron 14R Display Assembly Replacement, Disconnect the Display Cable: step 3, image 1 of 1
      • Disconnect the display cable from the connector on the system board.
      Ask FixBot
    4. Dell Inspiron 14R Display Assembly Replacement, Remove the Screws: step 4, image 1 of 1
      • Remove the four screws that secure the display assembly to the computer base.
      Ask FixBot
    5. Dell Inspiron 14R Display Assembly Replacement, Lifting the Display Assembly: step 5, image 1 of 1
      • Lift the display assembly off the computer base.
      Ask FixBot
    6. Dell Inspiron 14R Display Assembly Replacement, Place the Display Assembly: step 6, image 1 of 1
      • Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
      Ask FixBot
    7. Dell Inspiron 14R Display Assembly Replacement, Routing the Cable: step 7, image 1 of 1
      • Route the display cable and Mini-Card antenna cables through the routing guides.
      Ask FixBot
    8. Dell Inspiron 14R Display Assembly Replacement, Connect the Display Cable: step 8, image 1 of 1
      • Connect the display cable to the connector on the system board.
      Ask FixBot
    9. Dell Inspiron 14R Display Assembly Replacement, Tighten the Grounding Screw: step 9, image 1 of 1
      • Tighten the display cable grounding screw.
      Ask FixBot
    10. Dell Inspiron 14R Display Assembly Replacement, Replace the Screws: step 10, image 1 of 1
      • Replace the two screws at the bottom of the computer.
      Ask FixBot
Finish Line
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 61
All Time: 541
