Dell Inspiron 14R 5420 Memory Modules Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
14
Past 30 Days:
78
All Time:
562
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 seconds - 1 minute
Difficulty: Very easy
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Memory Modules.
    1. Dell Inspiron 14R 5420 Memory Modules Replacement, Popping up the Memory Module: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
      • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
      Ask FixBot
    2. Dell Inspiron 14R 5420 Memory Modules Replacement, Remove the Memory Module: step 2, image 1 of 1
      • Remove the memory module from the memory-module connector.
      Ask FixBot
    3. Dell Inspiron 14R 5420 Memory Modules Replacement, Align the Notch: step 3, image 1 of 1
      • Align the notch on the NEW memory module with the tab on the memory-module connector.
      Ask FixBot
    4. Dell Inspiron 14R 5420 Memory Modules Replacement, Installing the Memory Module: step 4, image 1 of 1
      • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
      • NOTE: If the memory module is not installed properly, the computer may not boot.
      Ask FixBot
Finish Line
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 78
All Time: 562
