Dell Inspiron 1464 Display Assembly Replacement
    1. Dell Inspiron 1464 Display Assembly Replacement, Note the Routing: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
      • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the bottom of the computer.
      Ask FixBot
    2. Dell Inspiron 1464 Display Assembly Replacement, Remove the Screws: step 2, image 1 of 1
      • Remove the two screws on the bottom of the computer that secure the display assembly to the computer base.
      Ask FixBot
    3. Dell Inspiron 1464 Display Assembly Replacement, Pull the Cables Up: step 3, image 1 of 1
      • Pull the Mini-Card antenna cables up through the slot in the computer base.
      Ask FixBot
    4. Dell Inspiron 1464 Display Assembly Replacement, Note the Routing: step 4, image 1 of 1
      • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the palm rest.
      Ask FixBot
    5. Dell Inspiron 1464 Display Assembly Replacement, Disconnect the Display Cable: step 5, image 1 of 1
      • Disconnect the display cable from the connector on the system board and remove the display cable grounding screw.
      Ask FixBot
    6. Dell Inspiron 1464 Display Assembly Replacement, Remove the Screws: step 6, image 1 of 1
      • Remove the three screws that secure the display assembly to the computer base.
      Ask FixBot
    7. Dell Inspiron 1464 Display Assembly Replacement, Removing the Display Assembly: step 7, image 1 of 1
      • Lift the display assembly off the alignment posts on the computer base.
      Ask FixBot
    8. Dell Inspiron 1464 Display Assembly Replacement, Placing the Display Assembly: step 8, image 1 of 1
      • Use the alignment posts to place the NEW display assembly on the computer base.
      Ask FixBot
    9. Dell Inspiron 1464 Display Assembly Replacement, Replace the Screws: step 9, image 1 of 1
      • Replace the three screws that secure the display assembly to the computer base.
      Ask FixBot
    10. Dell Inspiron 1464 Display Assembly Replacement, Connecting the Display Cable: step 10, image 1 of 1
      • Connect the display cable to the connector on the system board and replace the display cable grounding screw.
      Ask FixBot
    11. Dell Inspiron 1464 Display Assembly Replacement, Routing the Cables: step 11, image 1 of 1
      • Route the Mini-Card antenna cables through the routing guides on the palm rest.
      Ask FixBot
    12. Dell Inspiron 1464 Display Assembly Replacement, Thread the Cables: step 12, image 1 of 1
      • Thread the Mini-Card antenna cables through the slot in the computer base.
      Ask FixBot
    13. Dell Inspiron 1464 Display Assembly Replacement, Replace the Screws: step 13, image 1 of 1
      • Turn the computer over and replace the two screws that secure the display assembly to the computer base.
      Ask FixBot
Finish Line
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 61
All Time: 670
