Dell Inspiron 1428 Hard Drive Replacement
    1. Dell Inspiron 1428 Hard Drive Replacement, Remove the Screws: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in "Before You Begin".
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
      • Remove the two screws that secure the hard-drive cover to the computer base.
      Ask FixBot
    2. Dell Inspiron 1428 Hard Drive Replacement, Pry out te Hard-Drive Cover: step 2, image 1 of 1
      • Pry out the hard-drive cover using your finger.
      Ask FixBot
    3. Dell Inspiron 1428 Hard Drive Replacement, Remove the Screws: step 3, image 1 of 1
      • Remove the two screws that secure the hard-drive assembly to the computer base.
      Ask FixBot
    4. Dell Inspiron 1428 Hard Drive Replacement, Disconnecting the Hard Drive Assembly: step 4, image 1 of 1
      • Pull the pull-tab on the hard-drive assembly towards the right to disconnect the hard-drive assembly from the system board connector.
      Ask FixBot
    5. Dell Inspiron 1428 Hard Drive Replacement, Lifting the Hard-Drive Assembly: step 5, image 1 of 1
      • Lift the hard-drive assembly out of the computer base.
      Ask FixBot
    6. Dell Inspiron 1428 Hard Drive Replacement, Remove the Screws: step 6, image 1 of 1
      • Remove the four screws that secure the hard drive to the hard-drive cage.
      Ask FixBot
    7. Dell Inspiron 1428 Hard Drive Replacement, Placing the Hard Drive: step 7, image 1 of 1
      • Place the NEW hard drive in the hard-drive cage.
      Ask FixBot
    8. Dell Inspiron 1428 Hard Drive Replacement, Replace the Screws: step 8, image 1 of 1
      • Replace the four screws that secure the hard drive to the hard-drive cage.
      Ask FixBot
    9. Dell Inspiron 1428 Hard Drive Replacement, Placing the Hard-Drive Assembly: step 9, image 1 of 1
      • Place the NEW hard-drive assembly in the computer base.
      Ask FixBot
    10. Dell Inspiron 1428 Hard Drive Replacement, Connecting the Hard-Drive Assembly: step 10, image 1 of 1
      • Slide and connect the hard-drive assembly to the system board connector.
      Ask FixBot
    11. Dell Inspiron 1428 Hard Drive Replacement, Replace the Screws: step 11, image 1 of 1
      • Replace the two screws that secure the hard-drive assembly to the computer base.
      Ask FixBot
    12. Dell Inspiron 1428 Hard Drive Replacement, Align the Tabs: step 12, image 1 of 1
      • Align the tabs on the hard-drive cover with the slots on the computer base and snap the hard-drive cover into place.
      Ask FixBot
    13. Dell Inspiron 1428 Hard Drive Replacement, Replace the Screws: step 13, image 1 of 1
      • Replace the two screws that secure the hard-drive cover to the computer base.
      Ask FixBot
Finish Line
Terrence15
80,125 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,136 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 20
All Time: 237
