Dell Inspiron 1428 Display Assembly Replacement
    1. Dell Inspiron 1428 Display Assembly Replacement, Routing the Cables: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in "Before You Begin".
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • Make note of the Mini-Card antenna cables routing and remove the cables from the routing guides.
      Ask FixBot
    2. Dell Inspiron 1428 Display Assembly Replacement, Remove the Screws: step 2, image 1 of 1
      • Remove the four screws that secure the display assembly to the computer base.
      Ask FixBot
    3. Dell Inspiron 1428 Display Assembly Replacement, Dislodging the Cables: step 3, image 1 of 1
      • Make note of the Mini-Card antenna cable routing and carefully dislodge the antenna cables from the cable routing slot on the computer. Pull the cables away, so that they are clear of the palm rest.
      Ask FixBot
    4. Dell Inspiron 1428 Display Assembly Replacement, Disconnecting the cables: step 4, image 1 of 1
      • Disconnect the display cable, inverter board cable, camera cable, and microphone cables from the respective system board connectors.
      Ask FixBot
    5. Dell Inspiron 1428 Display Assembly Replacement, Remove the Cables: step 5, image 1 of 1
      • Remove the cables from their routing guides.
      Ask FixBot
    6. Dell Inspiron 1428 Display Assembly Replacement, Remove the Screws: step 6, image 1 of 1
      • Remove the two screws that secure the display assembly to the computer base.
      Ask FixBot
    7. Dell Inspiron 1428 Display Assembly Replacement, Lifting the Display Assembly: step 7, image 1 of 1
      • Lift the display assembly off the computer.
      Ask FixBot
    8. Dell Inspiron 1428 Display Assembly Replacement, Placing the Display Assembly: step 8, image 1 of 1
      • Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
      Ask FixBot
    9. Dell Inspiron 1428 Display Assembly Replacement, Routing the Cable: step 9, image 1 of 1
      • Route all the cables through the routing guides.
      Ask FixBot
    10. Dell Inspiron 1428 Display Assembly Replacement, Connecting the Cables: step 10, image 1 of 1
      • Connect the display cable, inverter board cable, and the camera cable to their respective system board connectors.
      Ask FixBot
Finish Line
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 63
All Time: 384
