Dell Inspiron 1425 Hard-Drive Assembly Replacement
    1. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Remove the Screw: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • Remove the screw that secures the hard-drive assembly to the system board.
      Ask FixBot
    2. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Sliding the Hard Drive Assembly: step 2, image 1 of 1
      • Slide the hard-drive assembly in the direction shown in the illustration to disconnect it from the connector on the system board.
      Ask FixBot
    3. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Lifting the Hard-Drive Assembly: step 3, image 1 of 1
      • Lift the hard-drive assembly off the system board.
      Ask FixBot
    4. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Remove the Screws: step 4, image 1 of 1
      • Remove the four screws that secure the hard-drive bracket to the hard drive.
      Ask FixBot
    5. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Lifting the Hard Drive: step 5, image 1 of 2 Dell Inspiron 1425 Hard-Drive Assembly Replacement, Lifting the Hard Drive: step 5, image 2 of 2
      • Lift the hard drive away from the hard-drive bracket.
      Ask FixBot
    6. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Placing the Hard Drive: step 6, image 1 of 1
      • Place the hard drive in the hard-drive bracket.
      Ask FixBot
    7. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Replace the Screws: step 7, image 1 of 1
      • Replace the four screws that secure the hard-drive bracket to the hard drive.
      Ask FixBot
    8. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Placing the Hard Drive Assembly: step 8, image 1 of 1
      • Place the NEW hard-drive assembly on the system board.
      Ask FixBot
    9. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Slding the Hard-Drive Assembly: step 9, image 1 of 1
      • Slide the hard-drive assembly to connect it to the connector on the system board.
      Ask FixBot
    10. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Replace the Screw: step 10, image 1 of 1
      • Replace the screw that secures the hard-drive assembly to the system board.
      Ask FixBot
Finish Line
Terrence15
80,125 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,136 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 321
