Dell Inspiron 1420 Keyboard Replacement
    1. Dell Inspiron 1420 Keyboard Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 1420 Keyboard Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 1420 Keyboard Replacement, Battery: step 1, image 3 of 3
      • Slide the two tabs to release the battery.
      • Pull the battery out.
      Ask FixBot
    1. Dell Inspiron 1420 Keyboard Replacement, Open the laptop: step 2, image 1 of 1
      • Open the lid as far back as possible.
      Ask FixBot
    2. Dell Inspiron 1420 Keyboard Replacement, Remove top cover plate: step 3, image 1 of 2 Dell Inspiron 1420 Keyboard Replacement, Remove top cover plate: step 3, image 2 of 2
      • Using a spudger, pry off the top cover plate, thus exposing the screws for the keyboard.
      Ask FixBot
    3. Dell Inspiron 1420 Keyboard Replacement, Unscrew keyboard screws: step 4, image 1 of 3 Dell Inspiron 1420 Keyboard Replacement, Unscrew keyboard screws: step 4, image 2 of 3 Dell Inspiron 1420 Keyboard Replacement, Unscrew keyboard screws: step 4, image 3 of 3
      • Using a Phillips #00 screwdriver, unscrew the two 3mm screws holding the keyboard down.
      • When removing the keyboard, be cautious not to damage the connecting ribbon underneath.
      Ask FixBot
    4. Dell Inspiron 1420 Keyboard Replacement, Remove keyboard: step 5, image 1 of 3 Dell Inspiron 1420 Keyboard Replacement, Remove keyboard: step 5, image 2 of 3 Dell Inspiron 1420 Keyboard Replacement, Remove keyboard: step 5, image 3 of 3
      • Using a spudger, carefully lift the blue tab, releasing the ribbon connector and freeing the keyboard to be removed.
      Ask FixBot
3 other people completed this guide.
Brandon
55 Reputation
1 Guide authored
USF Tampa, Team 2-4, Blackwell Fall 2014 Member of USF Tampa, Team 2-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 104
All Time: 2,106
