Dell Inspiron 1420 Display Replacement
    1. Dell Inspiron 1420 Display Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 1420 Display Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 1420 Display Replacement, Battery: step 1, image 3 of 3
      • Slide the two tabs to release the battery.
      • Pull the battery out.
      Ask FixBot
    1. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: step 2, image 1 of 3 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: step 2, image 2 of 3 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: step 2, image 3 of 3
      • Use a spudger to pry the 6 rubber bumpers from the display.
      • Using a Phillips #00 screwdriver, remove the six 4mm screws that are beneath the six rubber bumpers.
      Ask FixBot
    2. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: step 3, image 1 of 3 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: step 3, image 2 of 3 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: step 3, image 3 of 3
      • Gently pry the frame using a spudger.
      • Using a Phillips #00 screwdriver, remove the two 5mm screws at the bottom of the screen.
      Ask FixBot
    3. Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: step 4, image 1 of 3 Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: step 4, image 2 of 3 Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: step 4, image 3 of 3
      • Use a spudger to loosen the frame from the top.
      • Lift up the black connector to detach the gold ribbon.
      Ask FixBot
    4. Dell Inspiron 1420 Display Replacement, Removing the Power Connector Cable: step 5, image 1 of 2 Dell Inspiron 1420 Display Replacement, Removing the Power Connector Cable: step 5, image 2 of 2
      • Pull directly up on the light blue tab.
      Ask FixBot
    5. Dell Inspiron 1420 Display Replacement, VGA cable: step 6, image 1 of 3 Dell Inspiron 1420 Display Replacement, VGA cable: step 6, image 2 of 3 Dell Inspiron 1420 Display Replacement, VGA cable: step 6, image 3 of 3
      • Squeeze the two metal clips located on the VGA cable.
      • Pull while squeezing the clips in order to remove the cable.
      Ask FixBot
    6. Dell Inspiron 1420 Display Replacement, Isolating the Display: step 7, image 1 of 3 Dell Inspiron 1420 Display Replacement, Isolating the Display: step 7, image 2 of 3 Dell Inspiron 1420 Display Replacement, Isolating the Display: step 7, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the three 3mm screws located on both the left and right side of the laptop.
      • Remove the metal brackets, one on each side, by gently pulling.
      Ask FixBot
3 other people completed this guide.
Kris Karanxha
298 Reputation
1 Guide authored
USF Tampa, Team 2-4, Blackwell Fall 2014 Member of USF Tampa, Team 2-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 102
All Time: 3,128
