Dell Inspiron 1420 Disassembly
    1. Dell Inspiron 1420 Disassembly, Remove Battery: step 1, image 1 of 2 Dell Inspiron 1420 Disassembly, Remove Battery: step 1, image 2 of 2
      • Press both indicated locks on the bottom side of the laptop to release and remove the battery.
      Ask FixBot
    2. Dell Inspiron 1420 Disassembly, Unscrew Back Panel Screws: step 2, image 1 of 2 Dell Inspiron 1420 Disassembly, Unscrew Back Panel Screws: step 2, image 2 of 2
      • Loosen and remove indicated screws on the back panel using a Phillips #1 screwdriver.
      • Back cover screws
      • These screws are a different length than the others and can be stored separately for reassembly.
      • Hard drive cover screws
      • RAM cover screws
      • CD drive cover screw
      • Heat sink cover screws
      Ask FixBot
    3. Dell Inspiron 1420 Disassembly, Remove Hard Drive: step 3, image 1 of 1
      • Remove the hard drive cover.
      • Pull the tab in the direction of the arrows to remove the hard drive.
      Ask FixBot
    4. Dell Inspiron 1420 Disassembly, Remove CD Drive: step 4, image 1 of 2 Dell Inspiron 1420 Disassembly, Remove CD Drive: step 4, image 2 of 2
      • Using a screwdriver, slide out the CD drive bracket enough for it to be grabbed.
      • Remove CD drive from housing.
      Ask FixBot
    5. Dell Inspiron 1420 Disassembly, Remove RAM: step 5, image 1 of 2 Dell Inspiron 1420 Disassembly, Remove RAM: step 5, image 2 of 2
      • Remove RAM cover.
      • Pull the metal tabs above and below the RAM outward and remove both RAM sticks.
      Ask FixBot
    6. Dell Inspiron 1420 Disassembly, Remove Heat Sink: step 6, image 1 of 3 Dell Inspiron 1420 Disassembly, Remove Heat Sink: step 6, image 2 of 3 Dell Inspiron 1420 Disassembly, Remove Heat Sink: step 6, image 3 of 3
      • Remove the heat sink cover.
      • Using a Phillips #1 screwdriver, loosen and remove screws from heat sink.
      • Remove the heat sink.
      Ask FixBot
    7. Dell Inspiron 1420 Disassembly, Remove CPU: step 7, image 1 of 3 Dell Inspiron 1420 Disassembly, Remove CPU: step 7, image 2 of 3 Dell Inspiron 1420 Disassembly, Remove CPU: step 7, image 3 of 3
      • Using a flathead screwdriver, quarter turn the screw anticlockwise to release the CPU.
      • Gently lift the CPU out of the housing.
      • The pins on the bottom of the CPU are very fragile and will not function if any are bent.
      Ask FixBot
    8. Dell Inspiron 1420 Disassembly, Remove Bracket: step 8, image 1 of 2 Dell Inspiron 1420 Disassembly, Remove Bracket: step 8, image 2 of 2
      • Using a Phillips #1 screwdriver, unscrew and remove bracket.
      • There may be a card along with the bracket in your machine. If there is, unplug and remove this card as well.
      Ask FixBot
    9. Dell Inspiron 1420 Disassembly, Remove Back Screws: step 9, image 1 of 1
      • Using a Phillips #1 screwdriver, loosen and remove the indicated screws.
      Ask FixBot
    10. Dell Inspiron 1420 Disassembly, Pry Control Panel: step 10, image 1 of 1
      • Use a spudger to pry off the control panel.
      Ask FixBot
    11. Dell Inspiron 1420 Disassembly, Pry Hinge Covers: step 11, image 1 of 1
      • Use a spudger to pry off the hinge covers.
      Ask FixBot
    12. Dell Inspiron 1420 Disassembly, Remove Keyboard Screws: step 12, image 1 of 1
      • Using a Phillips #1 screwdriver, loosen and remove the keyboard screws.
      Ask FixBot
    13. Dell Inspiron 1420 Disassembly, Remove Keyboard: step 13, image 1 of 2 Dell Inspiron 1420 Disassembly, Remove Keyboard: step 13, image 2 of 2
      • Gently lift keyboard to reveal blue ribbon connection.
      • Use a spudger to flip the blue ribbon lever and release the keyboard.
      Ask FixBot
    14. Dell Inspiron 1420 Disassembly, Remove Wifi-Card: step 14, image 1 of 2 Dell Inspiron 1420 Disassembly, Remove Wifi-Card: step 14, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the screw holding in the Wi-Fi card.
      • Unplug cables connected to Wi-Fi card.
      • Slide Wi-Fi card out of connection to remove.
      Ask FixBot
    15. Dell Inspiron 1420 Disassembly, Lift Control Panel: step 15, image 1 of 2 Dell Inspiron 1420 Disassembly, Lift Control Panel: step 15, image 2 of 2
      • Using a Phillips #1 screwdriver, loosen and remove control panel screw.
      • Carefully pull up control panel. Being sure to keep the cable attached, set to the side.
      Ask FixBot
    16. Dell Inspiron 1420 Disassembly, Remove Monitor: step 16, image 1 of 2 Dell Inspiron 1420 Disassembly, Remove Monitor: step 16, image 2 of 2
      • Pull the blue tab up to release the monitor.
      • Remove monitor.
      Ask FixBot
    17. Dell Inspiron 1420 Disassembly, Remove Screws: step 17, image 1 of 1
      • Using a Phillips #1 screwdriver, remove remaining screws from cover panel.
      Ask FixBot
    18. Dell Inspiron 1420 Disassembly, Unplug Connections: step 18, image 1 of 3 Dell Inspiron 1420 Disassembly, Unplug Connections: step 18, image 2 of 3 Dell Inspiron 1420 Disassembly, Unplug Connections: step 18, image 3 of 3
      • Using a spudger, disconnect control panel motherboard cable.
      • Using a spudger, flip up blue lever and disconnect touchpad cable.
      Ask FixBot
    19. Dell Inspiron 1420 Disassembly, Remove Screws and Connections: step 19, image 1 of 1
      • Lift off cover panel.
      • Using a Phillips #1 screwdriver, loosen and remove screws from motherboard.
      • Disconnect the indicated cables from the motherboard.
      Ask FixBot
    20. Dell Inspiron 1420 Disassembly, Remove SIM Board: step 20, image 1 of 1
      • Using a Phillips #1 screwdriver, remove screw.
      • Disconnect indicated cable and remove SIM board.
      Ask FixBot
    21. Dell Inspiron 1420 Disassembly, Remove Memory Card Holder: step 21, image 1 of 1
      • Slide memory card holder out of housing.
      Ask FixBot
    22. Dell Inspiron 1420 Disassembly, Remove Modem Card: step 22, image 1 of 1
      • Flip laptop over to show backplate.
      • Loosen and remove modem card screw using a Phillips #1 screwdriver.
      • Remove modem card.
      Ask FixBot
    23. Dell Inspiron 1420 Disassembly, Release Motherboard: step 23, image 1 of 2 Dell Inspiron 1420 Disassembly, Release Motherboard: step 23, image 2 of 2
      • Flip laptop over and gently pull motherboard away from backplate.
      • Disconnect the indicated connection to release the motherboard.
      Ask FixBot
3 other people completed this guide.
Braxton Quillin
184 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 34
Past 30 Days: 100
All Time: 684
