Dell Inspiron 1410 Display Assembly Replacement
    1. Dell Inspiron 1410 Display Assembly Replacement, Removing the Mylar Tape: step 1, image 1 of 3 Dell Inspiron 1410 Display Assembly Replacement, Removing the Mylar Tape: step 1, image 2 of 3 Dell Inspiron 1410 Display Assembly Replacement, Removing the Mylar Tape: step 1, image 3 of 3
      • Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before Working Inside Your Computer.
      • Remove the mylar tapes and then remove the two screws from the back of the computer.
      Ask FixBot
    2. Dell Inspiron 1410 Display Assembly Replacement, Disconnecting the Display Cable: step 2, image 1 of 1
      • NOTE: Note how the display cable is routed through their routing guides.
      • Pull the display cable tab to disconnect the display cable from the system board connector.
      Ask FixBot
    3. Dell Inspiron 1410 Display Assembly Replacement, Dislodging the Cables: step 3, image 1 of 1
      • Make note of the cable routing and carefully dislodge the WLAN antenna cables and the rest of the cables from their routing guides. Pull the cables away, so that they are clear of the palm rest.
      Ask FixBot
    4. Dell Inspiron 1410 Display Assembly Replacement, Remove the Screws: step 4, image 1 of 1
      • Remove the two screws from either side of the display hinges.
      Ask FixBot
    5. Dell Inspiron 1410 Display Assembly Replacement, Removing the Display Assembly: step 5, image 1 of 1
      • Lift and remove the display assembly.
      Ask FixBot
    6. Dell Inspiron 1410 Display Assembly Replacement, Placing the Display Assembly: step 6, image 1 of 1
      • Place the NEW display assembly in place and replace the two screws on each side of the display hinges.
      Ask FixBot
    7. Dell Inspiron 1410 Display Assembly Replacement, Connecting the Display Cable: step 7, image 1 of 1
      • Re-route and connect the display cable to the connector on the system board.
      Ask FixBot
    8. Dell Inspiron 1410 Display Assembly Replacement, Routing the Antenna Cables: step 8, image 1 of 1
      • Carefully route the WLAN antenna cables into their routing guides on the palm rest and through the computer base.
      Ask FixBot
Finish Line
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 56
All Time: 551
