Dell Inspiron 14-5447 Keyboard Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
35
Past 30 Days:
109
All Time:
1,887
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Remember, turning off your device and removing it from any power source before you start reparations is important for your safety to prevent any electrical shock. Tools included in the reparation include a plastic prying tool and if needed a tweezer to disconnect the cables attached to the keyboard.
Tools
    1. Dell Inspiron 14-5447 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop upside down to access the battery.
      Ask FixBot
    2. Dell Inspiron 14-5447 Keyboard Replacement: step 2, image 1 of 2 Dell Inspiron 14-5447 Keyboard Replacement: step 2, image 2 of 2
      • Remove the two black 5.70mm Phillips#0 screws on the case's back.
      • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
      Ask FixBot
    3. Dell Inspiron 14-5447 Keyboard Replacement: step 3, image 1 of 2 Dell Inspiron 14-5447 Keyboard Replacement: step 3, image 2 of 2
      • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
      • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
      Ask FixBot
    4. Dell Inspiron 14-5447 Keyboard Replacement: step 4, image 1 of 2 Dell Inspiron 14-5447 Keyboard Replacement: step 4, image 2 of 2
      • Use the black, plastic flap on the left side to pull the battery out.
      • Slowly lift the flap up and the battery should slide out.
      Ask FixBot
    1. Dell Inspiron 14-5447 Keyboard Replacement, Keyboard: step 5, image 1 of 3 Dell Inspiron 14-5447 Keyboard Replacement, Keyboard: step 5, image 2 of 3 Dell Inspiron 14-5447 Keyboard Replacement, Keyboard: step 5, image 3 of 3
      • Locate the five small slits at the top of the keyboard.
      • Using a plastic opening tool, carefully pry each slit to loosen the keyboard.
      • Slide the keyboard towards the screen at an angle for removal.
      • Be cautious when lifting the keyboard because there are secured, fragile wires connected underneath it.
      Ask FixBot
    2. Dell Inspiron 14-5447 Keyboard Replacement: step 6, image 1 of 2 Dell Inspiron 14-5447 Keyboard Replacement: step 6, image 2 of 2
      • If the keyboard is not lifted with caution, damage to the cables may occur.
      • Lift the keyboard and flip it onto the mouse-pad.
      Ask FixBot
    3. Dell Inspiron 14-5447 Keyboard Replacement: step 7, image 1 of 3 Dell Inspiron 14-5447 Keyboard Replacement: step 7, image 2 of 3 Dell Inspiron 14-5447 Keyboard Replacement: step 7, image 3 of 3
      • Locate the two cable connectors. These connectors secure the cables to the laptop with small, securing flaps.
      • To release the cables, take each flap and flip them upwards to the unlocking position.
      • Pull both the cables out after unlocking and set aside the keyboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 109
All Time: 1,887
