Dell Inspiron 14-5447 Fan Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
32
Past 30 Days:
106
All Time:
1,301
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will teach users how to replace a faulty fan for the Dell Inspiron 14-5447. With removal of the fan, cleaning any debris left behind will help your new fan run much quieter and have better cooling circulation.
Prior to beginning this repair, be sure to power off the laptop and unplug it from the power cord.
Parts
Tools
    1. Dell Inspiron 14-5447 Fan Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop upside down to access the battery.
      Ask FixBot
    2. Dell Inspiron 14-5447 Fan Replacement: step 2, image 1 of 2 Dell Inspiron 14-5447 Fan Replacement: step 2, image 2 of 2
      • Remove the two black 5.70mm Phillips#0 screws on the case's back.
      • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
      Ask FixBot
    3. Dell Inspiron 14-5447 Fan Replacement: step 3, image 1 of 2 Dell Inspiron 14-5447 Fan Replacement: step 3, image 2 of 2
      • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
      • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
      Ask FixBot
    4. Dell Inspiron 14-5447 Fan Replacement: step 4, image 1 of 2 Dell Inspiron 14-5447 Fan Replacement: step 4, image 2 of 2
      • Use the black, plastic flap on the left side to pull the battery out.
      • Slowly lift the flap up and the battery should slide out.
      Ask FixBot
    1. Dell Inspiron 14-5447 Fan Replacement, Fan: step 5, image 1 of 1
      • Locate the fan system in the top right corner.
      Ask FixBot
    2. Dell Inspiron 14-5447 Fan Replacement: step 6, image 1 of 2 Dell Inspiron 14-5447 Fan Replacement: step 6, image 2 of 2
      • Look along the wide line of white cable until you find the tab insert.
      • Remove the thick white cable crossing over the fan, using the blue spudger shown, to flip the securing flap holding down the cable.
      Ask FixBot
    3. Dell Inspiron 14-5447 Fan Replacement: step 7, image 1 of 2 Dell Inspiron 14-5447 Fan Replacement: step 7, image 2 of 2
      • Move the cable over to the side to reveal the fan screws.
      • Remove the two black 5.70 mm screws from the fan.
      Ask FixBot
    4. Dell Inspiron 14-5447 Fan Replacement: step 8, image 1 of 2 Dell Inspiron 14-5447 Fan Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove the small cable attached to the fan.
      Ask FixBot
    5. Dell Inspiron 14-5447 Fan Replacement: step 9, image 1 of 2 Dell Inspiron 14-5447 Fan Replacement: step 9, image 2 of 2
      • Using the opening tool, pry the fan out.
      • Remove the fan slowly to prevent damage to any wires or cables connected to the device.
      Ask FixBot
    6. Dell Inspiron 14-5447 Fan Replacement: step 10, image 1 of 1
      • Now that the fan is removed, be sure to clean the area under the fan to prevent overheating.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 106
All Time: 1,301
