Dell Inspiron 14-5425
    1. Dell Inspiron 14-5425, Screw removing (and addons): step 1, image 1 of 1
      • Flip your laptop rearside up. Make sure not to scratch anything while doing so.
      • Remove anything attached to your laptop and start unscrewing.
      • The blue circled screws are "stand-off screws", they shouldn’t come out the rear shell. Keep unscrewing until each of them start to make a "clicking" noise.
      • The red circled screws are normal, they are all the same size and should come out.
      Ask FixBot
    2. Dell Inspiron 14-5425, Lid removal: step 2, image 1 of 1
      • All the screws should be off except the "stand-off" screws.
      • Slide a pick or card around the computer lid. Don't dig too deep or you might hit something
      • Be wary that there is a clip near the middle of the rear shell. Lift the shell off with equal pressure. Make sure to take your time to prevent anything going wrong.
      Ask FixBot
    3. Dell Inspiron 14-5425, Cable disconnection/removal: step 3, image 1 of 3 Dell Inspiron 14-5425, Cable disconnection/removal: step 3, image 2 of 3 Dell Inspiron 14-5425, Cable disconnection/removal: step 3, image 3 of 3
      • The lid should come back off
      • Find the battery cable (near the bottom right)
      • Lift off a bit of the cable cover and use a tool to disconnect the cable
      • Disconnect the cable by pushing the cable out
      Ask FixBot
    4. Dell Inspiron 14-5425, Battery removal: step 4, image 1 of 1
      • Unscrew the battery from the laptop. All the screws are the same size
      • Use a card or pick to detach the battery
      • The battery isn’t glued in, it should be free
      Ask FixBot
    5. Dell Inspiron 14-5425, Done: step 5, image 1 of 1
      • You are done!
      Ask FixBot
WakandaMan99
149 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 110
All Time: 900
