Dell Inspiron 14-3452 Screen Replacement
    1. Dell Inspiron 14-3452 Screen Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 14-3452 Screen Replacement, Battery: step 1, image 2 of 2
      • Remove the battery by sliding the battery release latch to the left.
      • Pull the entire battery away from the backing.
      Ask FixBot
    1. Dell Inspiron 14-3452 Screen Replacement, Random Access Memory (RAM): step 2, image 1 of 1
      • Ensure that the laptop is completely turned off and the battery is removed.
      • Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
      Ask FixBot
    2. Dell Inspiron 14-3452 Screen Replacement: step 3, image 1 of 1
      • Pull the backing away from the laptop.
      Ask FixBot
    3. Dell Inspiron 14-3452 Screen Replacement: step 4, image 1 of 1
      • Locate the blue RAM chip sitting in the RAM bay.
      • Use your fingertips to pry apart the white RAM securing-clips on each side of the memory-module slot until the RAM chip pops up.
      Ask FixBot
    4. Dell Inspiron 14-3452 Screen Replacement: step 5, image 1 of 1
      • Pull the RAM chip away from the memory-module slot.
      • The RAM chip is now fully detached and ready to be replaced.
      Ask FixBot
    1. Dell Inspiron 14-3452 Screen Replacement, Screen: step 6, image 1 of 1
      • Remove the ten Phillips Head 5 mm #0 screws from the computer backing.
      • Remove the one Phillips Head 3 mm #0 screw from the computer backing.
      Ask FixBot
    2. Dell Inspiron 14-3452 Screen Replacement: step 7, image 1 of 2 Dell Inspiron 14-3452 Screen Replacement: step 7, image 2 of 2
      • Remove the white and black antenna cables from the wireless card.
      Ask FixBot
    3. Dell Inspiron 14-3452 Screen Replacement: step 8, image 1 of 1
      • Remove the Phillips Head 3 mm #0 screw that is holding the wireless card in place.
      Ask FixBot
    4. Dell Inspiron 14-3452 Screen Replacement: step 9, image 1 of 1
      • Slide the wireless card out of the wireless card bay.
      Ask FixBot
    5. Dell Inspiron 14-3452 Screen Replacement: step 10, image 1 of 2 Dell Inspiron 14-3452 Screen Replacement: step 10, image 2 of 2
      • Using your fingertips remove the speaker cable from the motherboard by pulling the white connector away from the socket.
      Ask FixBot
    6. Dell Inspiron 14-3452 Screen Replacement: step 11, image 1 of 1
      • Pry apart the keyboard assembly slowly as the keyboard cable will still be attached to the motherboard.
      • Use the blue Uspudger to pry apart the keyboard assembly from the bottom shell.
      Ask FixBot
    7. Dell Inspiron 14-3452 Screen Replacement: step 12, image 1 of 1
      • Disconnect the keyboard cable from the motherboard by lifting the black latch and pulling the cable out of its socket.
      Ask FixBot
    8. Dell Inspiron 14-3452 Screen Replacement: step 13, image 1 of 2 Dell Inspiron 14-3452 Screen Replacement: step 13, image 2 of 2
      • Disconnect the display cable from the motherboard by pulling the tape back and lifting the connector latch.
      • Pull the display cable away from the motherboard.
      Ask FixBot
    9. Dell Inspiron 14-3452 Screen Replacement: step 14, image 1 of 1
      • Remove the power adapter cable from the motherboard by sliding the cable out of its socket.
      Ask FixBot
    10. Dell Inspiron 14-3452 Screen Replacement: step 15, image 1 of 1
      • Turn laptop over to access the screen hinge screws.
      • Remove the two Phillips Head 5 mm #0 screws from the two hinges.
      Ask FixBot
    11. Dell Inspiron 14-3452 Screen Replacement: step 16, image 1 of 2 Dell Inspiron 14-3452 Screen Replacement: step 16, image 2 of 2
      • Using your fingertips, gently pry up the inner edges of the display bezel.
      • Lift the display bezel off the display assembly.
      Ask FixBot
    12. Dell Inspiron 14-3452 Screen Replacement: step 17, image 1 of 3 Dell Inspiron 14-3452 Screen Replacement: step 17, image 2 of 3 Dell Inspiron 14-3452 Screen Replacement: step 17, image 3 of 3
      • After removing the bezel, locate the tab indicated in the pictures.
      • Lift the tab as shown in the pictures.
      • Lift the gold latch securing the display cable to the socket.
      • Pull display cable away from the socket.
      Ask FixBot
Alec Siegel
598 Reputation
4 Guides authored
Baylor, Team S2-G2, Johnson Spring 2018 Member of Baylor, Team S2-G2, Johnson Spring 2018
BU-JOHNSON-S18S2G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 65
All Time: 1,379
