Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement
    1. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement, Battery: step 1, image 2 of 2
      • Remove the battery by sliding the battery release latch to the left.
      • Pull the entire battery away from the backing.
      Ask FixBot
    1. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): step 2, image 1 of 1
      • Ensure that the laptop is completely turned off and the battery is removed.
      • Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
      Ask FixBot
    2. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement: step 3, image 1 of 1
      • Pull the backing away from the laptop.
      Ask FixBot
    3. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement: step 4, image 1 of 1
      • Locate the blue RAM chip sitting in the RAM bay.
      • Use your fingertips to pry apart the white RAM securing-clips on each side of the memory-module slot until the RAM chip pops up.
      Ask FixBot
    4. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement: step 5, image 1 of 1
      • Pull the RAM chip away from the memory-module slot.
      • The RAM chip is now fully detached and ready to be replaced.
      Ask FixBot
2 other people completed this guide.
Alec Siegel
598 Reputation
4 Guides authored
Baylor, Team S2-G2, Johnson Spring 2018 Member of Baylor, Team S2-G2, Johnson Spring 2018
BU-JOHNSON-S18S2G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 69
All Time: 1,318
