Dell Inspiron 14 Gaming 7466 Display Assembly Replacement
    1. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Disconnecting the Camera Cable: step 1, image 1 of 1
      Ask FixBot
    2. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Peeling the Camera Cable: step 2, image 1 of 1
      • Peel off the camera cable from the computer base.
      Ask FixBot
    3. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Antenna Cables: step 3, image 1 of 1
      • Remove the antenna cables from the routing guides on the computer base.
      Ask FixBot
    4. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screw: step 4, image 1 of 1
      • Remove the screw (M2x3) that secures the display-cable bracket to the system board.
      Ask FixBot
    5. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Lifting the Display Cable Bracket: step 5, image 1 of 1
      • Lift the display-cable bracket off the system board.
      Ask FixBot
    6. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Disconnecting the Display Cable: step 6, image 1 of 1
      • Using the pull-tab, disconnect the display cable from the system board.
      Ask FixBot
    7. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Peel off the Display Cable: step 7, image 1 of 1
      • Peel off the display cable from the computer base.
      Ask FixBot
    8. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: step 8, image 1 of 1
      • Remove the two screws (M2x3) that secure the display assembly to the computer base.
      Ask FixBot
    9. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: step 9, image 1 of 1
      • Remove the two screws (M2.5x5) that secure the display assembly to the computer base.
      Ask FixBot
    10. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Open the Display: step 10, image 1 of 1
      • Turn the computer over and open the display.
      Ask FixBot
    11. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: step 11, image 1 of 1
      Ask FixBot
    12. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Lifting the Display Assembly: step 12, image 1 of 1
      • Lift the display assembly off the computer base.
      Ask FixBot
    13. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Align the Screw Holes: step 13, image 1 of 1
      • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
      Ask FixBot
    14. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: step 14, image 1 of 1
      • Replace the two screws (M2.5x5) that secure the display assembly to the computer base.
      Ask FixBot
    15. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: step 15, image 1 of 1
      • Close the display and turn the computer over.
      Ask FixBot
    16. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: step 16, image 1 of 1
      • Replace the two screws (M2x3) that secure the display assembly to the computer base.
      Ask FixBot
    17. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Adhering the Cables: step 17, image 1 of 1
      • Adhere the display cable and the camera cable to the computer base.
      Ask FixBot
    18. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Connect the Display Cable: step 18, image 1 of 1
      • Connect the display cable and camera cable to the system board.
      Ask FixBot
    19. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Align the Screw Hole: step 19, image 1 of 1
      • Align the screw hole on the display-cable bracket with the screw hole on the system board.
      Ask FixBot
    20. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screw: step 20, image 1 of 1
      • Replace the screw (M2x3) that secures the display cable bracket to the system board.
      Ask FixBot
Finish Line
Terrence15
80,125 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,155 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 380
