Dell Inspiron 14 7460 Memory Modules Replacement
    1. Dell Inspiron 14 7460 Memory Modules Replacement, Disconnecting the Battery Cable: step 1, image 1 of 1
      Ask FixBot
    2. Dell Inspiron 14 7460 Memory Modules Replacement, Remove the Screws: step 2, image 1 of 1
      • Remove the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
      Ask FixBot
    3. Dell Inspiron 14 7460 Memory Modules Replacement, Lifting the Battery: step 3, image 1 of 1
      • Lift the battery off the palm rest and keyboard assembly.
      Ask FixBot
      • Press and hold the power button for five seconds to ground the system board.
      Ask FixBot
    4. Dell Inspiron 14 7460 Memory Modules Replacement, Align the Screw Holes: step 5, image 1 of 1
      • Align the screw holes on the NEW battery with the screw holes on the palm rest and keyboard assembly.
      Ask FixBot
    5. Dell Inspiron 14 7460 Memory Modules Replacement, Replace the Screws: step 6, image 1 of 1
      • Replace the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
      Ask FixBot
    6. Dell Inspiron 14 7460 Memory Modules Replacement, Connecting the Battery Cable: step 7, image 1 of 1
      • Connect the battery cable to the system board.
      Ask FixBot
    1. Dell Inspiron 14 7460 Memory Modules Replacement, Popping up the Memory Module: step 8, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
      Ask FixBot
    2. Dell Inspiron 14 7460 Memory Modules Replacement, Removing the Memory Module: step 9, image 1 of 1
      • Remove the memory module from the memory-module slot.
      Ask FixBot
    3. Dell Inspiron 14 7460 Memory Modules Replacement, Align the Notch: step 10, image 1 of 1
      • Align the notch on the NEW memory module with the tab on the memory-module slot.
      Ask FixBot
    4. Dell Inspiron 14 7460 Memory Modules Replacement, Sliding the Memory Module: step 11, image 1 of 1
      • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
      • NOTE: If you do not hear the click, remove the memory module and reinstall it.
      Ask FixBot
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 76
All Time: 1,231
