Community-Contributed Guide
Introduction
Go to step 1 ↓In this guide, we will be showing you how to remove and replace the Display Assembly.
Tools
Peel off the tape and disconnect the display cable from the system board.
Note the display cable routing and remove the cable from its routing guide.
Note the antenna cable routing and remove the cables from their routing guide.
Using the pull-tab, disconnect the I/O-board cable from the I/O board.
Note the I/O-board cable routing and remove the cable from its routing guide.
Remove the screws that secure the display assembly to the computer base.
Place the NEW display assembly on the computer base and align the screw holes on the display assembly with the screw holes on the computer base.
Replace the screws that secure the display assembly to the computer base.
Route the I/O-board cable through the routing guides on the computer base.
Route the antenna cables through the routing guides on the computer base.
Route the display cable through the routing guides on the computer base.
Connect the display cable to the system board and adhere the tape.
