Dell Inspiron 14 5100 Hard Drive Replacement
    1. Dell Inspiron 14 5100 Hard Drive Replacement, Dell Inspiron 14 5100 Disassembly: step 1, image 1 of 3 Dell Inspiron 14 5100 Hard Drive Replacement, Dell Inspiron 14 5100 Disassembly: step 1, image 2 of 3 Dell Inspiron 14 5100 Hard Drive Replacement, Dell Inspiron 14 5100 Disassembly: step 1, image 3 of 3
      • Make sure to disconnect the power source to the device.
      • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
      • There are 2 sets of screws.
      • Remove the 3 captive screws.
      • Remove the 6M2*6 screws.
      Ask FixBot
    2. Dell Inspiron 14 5100 Hard Drive Replacement: step 2, image 1 of 2 Dell Inspiron 14 5100 Hard Drive Replacement: step 2, image 2 of 2
      • Pry open the laptop to separate the base cover from the keyboard assembly.
      • You may use your fingertips or use plastic opening tools.
      Ask FixBot
    1. Dell Inspiron 14 5100 Hard Drive Replacement, Battery: step 3, image 1 of 2 Dell Inspiron 14 5100 Hard Drive Replacement, Battery: step 3, image 2 of 2
      • Remove the four Phillips #0 screws securing the battery to the keyboard assembly.
      Ask FixBot
    2. Dell Inspiron 14 5100 Hard Drive Replacement: step 4, image 1 of 3 Dell Inspiron 14 5100 Hard Drive Replacement: step 4, image 2 of 3 Dell Inspiron 14 5100 Hard Drive Replacement: step 4, image 3 of 3
      • Peel off the tape securing the battery cable to the battery cable connector.
      • Disconnect and remove the old battery.
      Ask FixBot
    1. Dell Inspiron 14 5100 Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
      • Unplug the connectors from the hard drive and slide it out of its slot.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 66
All Time: 3,658
