Dell Inspiron 14 3467 Base Cover Replacement
    1. Dell Inspiron 14 3467 Base Cover Replacement, Turning over the Computer: step 1, image 1 of 1
      Ask FixBot
    2. Dell Inspiron 14 3467 Base Cover Replacement, Remove the Screws: step 2, image 1 of 1
      • Remove the eight screws that secure the base cover to the palm-rest assembly.
      Ask FixBot
    3. Dell Inspiron 14 3467 Base Cover Replacement, Removing the Screws: step 3, image 1 of 1
      • Remove the two screws that secure the base cover to the palm-rest assembly.
      Ask FixBot
    4. Dell Inspiron 14 3467 Base Cover Replacement, Removing the screws: step 4, image 1 of 1
      • Remove the three screws that secure the base cover to the palm-rest assembly.
      Ask FixBot
    5. Dell Inspiron 14 3467 Base Cover Replacement, Turning the Computer over: step 5, image 1 of 1
      • Turn the computer over, and open the display.
      Ask FixBot
    6. Dell Inspiron 14 3467 Base Cover Replacement, Removing the Screws: step 6, image 1 of 1
      Ask FixBot
    7. Dell Inspiron 14 3467 Base Cover Replacement, Disconnecting the Optical-Drive Cable: step 7, image 1 of 1
      • Open the latch, and disconnect the optical-drive cable from the system board.
      Ask FixBot
    8. Dell Inspiron 14 3467 Base Cover Replacement, Turning the Computer Over: step 8, image 1 of 1
      • Close the display, and turn the computer over
      Ask FixBot
    9. Dell Inspiron 14 3467 Base Cover Replacement, Prying the Base Cover: step 9, image 1 of 1
      • Using a plastic scribe, pry the base cover off the palm-rest assembly.
      Ask FixBot
    10. Dell Inspiron 14 3467 Base Cover Replacement, Lifting the Base Cover: step 10, image 1 of 1
      • Lift the base cover off the palm-rest assembly.
      Ask FixBot
    11. Dell Inspiron 14 3467 Base Cover Replacement, Release the Optical-Drive Interposer: step 11, image 1 of 1
      • Release the optical-drive interposer from the tabs, and remove it from the base cover.
      Ask FixBot
    12. Dell Inspiron 14 3467 Base Cover Replacement, Sliding the Optical-Drive: step 12, image 1 of 1
      • Slide the optical-drive interposer into the tabs on the NEW base cover and snap it into place.
      Ask FixBot
    13. Dell Inspiron 14 3467 Base Cover Replacement, Placing the Base Cover: step 13, image 1 of 1
      • Place the base cover on the palm-rest assembly and route the optical-drive cable through the slot on the palm-rest assembly.
      Ask FixBot
    14. Dell Inspiron 14 3467 Base Cover Replacement, Sliding the Tabs: step 14, image 1 of 1
      • Slide the tabs on the base cover into the slots on the palm-rest assembly, and snap the base cover into place.
      Ask FixBot
    15. Dell Inspiron 14 3467 Base Cover Replacement, Sliding the Optical-Drive Cable: step 15, image 1 of 1
      • Slide the optical-drive cable into the connector on the system board and press down the latch to secure the cable.
      Ask FixBot
    16. Dell Inspiron 14 3467 Base Cover Replacement, Placing the Screws: step 16, image 1 of 1
      • Replace the three screws (M2x5) that secure the base cover to the palm-rest assembly.
      Ask FixBot
    17. Dell Inspiron 14 3467 Base Cover Replacement, Turning over the Computer: step 17, image 1 of 1
      • Close the display, and turn the computer over.
      Ask FixBot
    18. Dell Inspiron 14 3467 Base Cover Replacement, Replacing the Screws: step 18, image 1 of 1
      • Replace the three screws (M2x2) that secure the base cover to the palm-rest assembly.
      Ask FixBot
    19. Dell Inspiron 14 3467 Base Cover Replacement, Replacing the Screws: step 19, image 1 of 1
      • Replace the two screws (M2x5) that secure the base cover to the palm-rest assembly.
      Ask FixBot
    20. Dell Inspiron 14 3467 Base Cover Replacement, Replacing the Screws: step 20, image 1 of 1
      • Replace the eight screws that secure the base cover to the palm-rest assembly.
      Ask FixBot
Finish Line
darrius
5,213 Reputation
30 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,153 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 46
All Time: 2,602
