Dell Inspiron 14 3462 Display Assembly Replacement
    1. Dell Inspiron 14 3462 Display Assembly Replacement, Peel the Tape: step 1, image 1 of 1
      Ask FixBot
    2. Dell Inspiron 14 3462 Display Assembly Replacement, Disconnecting the Display Cable: step 2, image 1 of 1
      • Open the latch that secures the display cable into position.
      • Disconnect the display cable from the system board.
      Ask FixBot
    3. Dell Inspiron 14 3462 Display Assembly Replacement, Remove the Antenna Cable: step 3, image 1 of 1
      • Note the antenna-cable routing, and remove the antenna cable from the routing guides on the palm-rest assembly.
      Ask FixBot
    4. Dell Inspiron 14 3462 Display Assembly Replacement, Turn the Computer Over: step 4, image 1 of 1
      • Turn the computer over and open the display at an angle of 90 degrees.
      • Turn the computer over and place it on the edge of the table in a position that allows access to the screws on the display hinges.
      Ask FixBot
    5. Dell Inspiron 14 3462 Display Assembly Replacement, Remove the Screws: step 5, image 1 of 1
      • Remove the three screws (M2.5x8) that secure the display-hinge brackets to the palm-rest assembly.
      Ask FixBot
    6. Dell Inspiron 14 3462 Display Assembly Replacement, Lifting the Display Assembly: step 6, image 1 of 1
      • Carefully lift the display assembly from the palm-rest assembly.
      Ask FixBot
    7. Dell Inspiron 14 3462 Display Assembly Replacement, Placing the Display Assembly: step 7, image 1 of 1
      • Carefully place the display assembly on a clean and flat surface.
      Ask FixBot
    8. Dell Inspiron 14 3462 Display Assembly Replacement, Placing the Display Assembly: step 8, image 1 of 1
      • Place the NEW display assembly at the edge of the table.
      Ask FixBot
    9. Dell Inspiron 14 3462 Display Assembly Replacement, Align the Screw Holes: step 9, image 1 of 1
      • Align the screw holes on the palm-rest assembly with the screw holes on the display hinges.
      Ask FixBot
    10. Dell Inspiron 14 3462 Display Assembly Replacement, Replace the Screws: step 10, image 1 of 1
      • Replace the three screws (M2.5x8) that secure the display hinges to the palm-rest assembly.
      Ask FixBot
    11. Dell Inspiron 14 3462 Display Assembly Replacement, Route the Cables: step 11, image 1 of 1
      • Route the antenna cables through the routing guides on the palm-rest assembly.
      Ask FixBot
    12. Dell Inspiron 14 3462 Display Assembly Replacement, Connecting the Display Cable: step 12, image 1 of 1
      • Connect the display cable from the system board.
      Ask FixBot
    13. Dell Inspiron 14 3462 Display Assembly Replacement, Close the Latch: step 13, image 1 of 1
      • Close the latch that secures the display cable to the system board.
      Ask FixBot
    14. Dell Inspiron 14 3462 Display Assembly Replacement, Adhering the Tape: step 14, image 1 of 1
      • Adhere the tape that secures the display cable to the system board.
      Ask FixBot
Finish Line
Terrence15
80,125 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,136 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 442
