Dell Inspiron 1320 Hard Drive Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
12
Past 30 Days:
77
All Time:
721
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 - 25 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide, we will show you how to remove and replace the Hard Drive.
Tools
    1. Dell Inspiron 1320 Hard Drive Replacement, Remove the Four Screws: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • Remove the four screws that secure the hard drive assembly to the computer base.
      Ask FixBot
    2. Dell Inspiron 1320 Hard Drive Replacement, Sliding the Hard Drive Assembly: step 2, image 1 of 1
      • Slide the hard drive assembly to disconnect it from the system board connector.
      Ask FixBot
    3. Dell Inspiron 1320 Hard Drive Replacement, Pull the Black Pull-Tab: step 3, image 1 of 1
      • Pull the black pull-tab and lift the hard drive assembly out of the computer base.
      Ask FixBot
    4. Dell Inspiron 1320 Hard Drive Replacement, Remove the Screws: step 4, image 1 of 1
      • Remove the four screws that secure the hard drive to the hard drive cage.
      Ask FixBot
    5. Dell Inspiron 1320 Hard Drive Replacement, Sliding the Hard Drive: step 5, image 1 of 1
      • Slide the hard drive out of the hard drive cage.
      Ask FixBot
    6. Dell Inspiron 1320 Hard Drive Replacement, Sliding the Hard Drive: step 6, image 1 of 2 Dell Inspiron 1320 Hard Drive Replacement, Sliding the Hard Drive: step 6, image 2 of 2
      • Slide the NEW hard drive into the hard drive cage.
      Ask FixBot
    7. Dell Inspiron 1320 Hard Drive Replacement, Replace the Screws: step 7, image 1 of 1
      • Replace the four screws that secure the hard drive to the hard drive cage.
      Ask FixBot
    8. Dell Inspiron 1320 Hard Drive Replacement, Placing the Hard Drive Assembly: step 8, image 1 of 1
      • Place the hard drive assembly in the computer base.
      Ask FixBot
    9. Dell Inspiron 1320 Hard Drive Replacement, Connecting the Hard Drive Assembly: step 9, image 1 of 1
      • Slide and connect the hard drive assembly to the system board connector.
      Ask FixBot
    10. Dell Inspiron 1320 Hard Drive Replacement, Replace the Screws: step 10, image 1 of 1
      • Replace the four screws that secure the hard drive assembly to the computer base.
      Ask FixBot
Finish Line
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 77
All Time: 721
