Dell Inspiron 1320 Display Assembly Replacement
    1. Dell Inspiron 1320 Display Assembly Replacement, Disconnecting the Display Cable: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer)
      • Disconnect the display cable and the camera cable from their respective system board connectors.
      Ask FixBot
    2. Dell Inspiron 1320 Display Assembly Replacement, Remove the Screws: step 2, image 1 of 1
      • Remove the six screws (three on each side) that secure the display assembly to the computer base.
      Ask FixBot
    3. Dell Inspiron 1320 Display Assembly Replacement, Dislodging the Antenna Cables: step 3, image 1 of 1
      • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
      Ask FixBot
      • Lift the display assembly off the computer.
      Ask FixBot
    4. Dell Inspiron 1320 Display Assembly Replacement, Placing the Display Assembly: step 5, image 1 of 1
      • Place the NEW display assembly in position and replace the six screws (three on each side) of the display assembly.
      Ask FixBot
      • Route the Mini-Card antenna cables through the routing guides.
      Ask FixBot
    5. Dell Inspiron 1320 Display Assembly Replacement, Connecting the Display Cable: step 7, image 1 of 1
      • Connect the display cable and the camera cable to their respective system board connectors.
      Ask FixBot
Finish Line
2 other people completed this guide.
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 65
All Time: 635
