Dell Inspiron 1318 Memory Module Replacement
    1. Dell Inspiron 1318 Memory Module Replacement, Popping up the Memory Module: step 1, image 1 of 1
      • Follow the procedures in Before You Begin.
      • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      Ask FixBot
    2. Dell Inspiron 1318 Memory Module Replacement, Remove the Module: step 2, image 1 of 1
      • Remove the module from the connector.
      Ask FixBot
    3. Dell Inspiron 1318 Memory Module Replacement, Align the Notch: step 3, image 1 of 1
      • Align the notch in the module edge connector with the tab in the connector slot.
      Ask FixBot
    4. Dell Inspiron 1318 Memory Module Replacement, Sliding the Module: step 4, image 1 of 1
      • Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If the module does not click into place, remove the module and reinstall it.
      • NOTE: If the memory module is not installed properly, the computer may not boot.
      Ask FixBot
Finish Line
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 52
All Time: 361
