Dell Inspiron 1318 Display Assembly Replacement
    1. Dell Inspiron 1318 Display Assembly Replacement, Removing the Antenna Cables: step 1, image 1 of 1
      • Make note of the cable routing and carefully remove the antenna cables from their routing guides. Pull the cables with their connectors through the system board so that they are clear of the computer base.
      Ask FixBot
    2. Dell Inspiron 1318 Display Assembly Replacement, Removing the Screws: step 2, image 1 of 1
      • Remove the two M2.5 x 5-mm screws from the computer base.
      • NOTE: Note how the display cable and the camera cable have been routed through their routing guides.
      Ask FixBot
    3. Dell Inspiron 1318 Display Assembly Replacement, Disconnecting the Display Cable: step 3, image 1 of 1
      • Pull the display cable tab to disconnect the display cable from the system board connector.
      Ask FixBot
    4. Dell Inspiron 1318 Display Assembly Replacement, Disconnecting the Camera Cable: step 4, image 1 of 1
      • Disconnect the camera cable from the system board connector.
      Ask FixBot
    5. Dell Inspiron 1318 Display Assembly Replacement, Dislodging the Cables: step 5, image 1 of 1
      • Make note of the cable routing and carefully dislodge the antenna cables and the rest of the cables from their routing guides. Pull the cables away, so that they are clear of the palm rest.
      Ask FixBot
    6. Dell Inspiron 1318 Display Assembly Replacement, Remove the Screws: step 6, image 1 of 1
      • Remove the two M2.5 x 5-mm screws from either side of the display assembly.
      Ask FixBot
    7. Dell Inspiron 1318 Display Assembly Replacement, Removing the Display Assembly: step 7, image 1 of 1
      • Lift and remove the display assembly from the computer base.
      Ask FixBot
    8. Dell Inspiron 1318 Display Assembly Replacement, Routing the Cables: step 8, image 1 of 1
      • Route and connect the display cable to the connector on the system board.
      • Route and connect the camera cable to the connector on the system board.
      • Carefully route the WLAN antenna cables into their routing guides on the palm rest and through the computer base.
      Ask FixBot
    9. Dell Inspiron 1318 Display Assembly Replacement, Replace the Screws: step 9, image 1 of 1
      • Replace the two M2.5 x 5-mm screws on each side of the display assembly.
      Ask FixBot
    10. Dell Inspiron 1318 Display Assembly Replacement, Turn the Computer Over: step 10, image 1 of 1
      • Turn the computer over and replace the two M2.5 x 5-mm screws on the computer base.
      Ask FixBot
    11. Dell Inspiron 1318 Display Assembly Replacement, Routing the Cables: step 11, image 1 of 1
      • Carefully route the WLAN card antenna cables through their routing guides and connect them to the WLAN card.
      Ask FixBot
Finish Line
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 58
All Time: 530
