Dell Inspiron 13-7370 Fan Replacement
    1. Dell Inspiron 13-7370 Fan Replacement, Fan: step 1, image 1 of 3 Dell Inspiron 13-7370 Fan Replacement, Fan: step 1, image 2 of 3 Dell Inspiron 13-7370 Fan Replacement, Fan: step 1, image 3 of 3
      • Make sure the laptop is turned off and not connected to a charging cable.
      • Using a Phillips #0 screwdriver, remove the ten (10) 2.5 mm screws fastening the bottom cover.
      Ask FixBot
    2. Dell Inspiron 13-7370 Fan Replacement: step 2, image 1 of 2 Dell Inspiron 13-7370 Fan Replacement: step 2, image 2 of 2
      • Starting around the edges of the laptop, lift and remove the back cover. Apply pressure upwards, until you hear a popping noise.
      • Moving clockwise around the laptop, continue to apply pressure upwards, using your fingers or a plastic pick, until the bottom cover pops out of its locks.
      Ask FixBot
    3. Dell Inspiron 13-7370 Fan Replacement: step 3, image 1 of 2 Dell Inspiron 13-7370 Fan Replacement: step 3, image 2 of 2
      • Using the Phillips #0 screwdriver, remove the four 2 mm screws.
      • Carefully disconnect the battery from the motherboard.
      Ask FixBot
    4. Dell Inspiron 13-7370 Fan Replacement: step 4, image 1 of 2 Dell Inspiron 13-7370 Fan Replacement: step 4, image 2 of 2
      • Using the Phillips #0 screwdriver, remove the two 2 mm screws holding the fan in place.
      Ask FixBot
    5. Dell Inspiron 13-7370 Fan Replacement: step 5, image 1 of 3 Dell Inspiron 13-7370 Fan Replacement: step 5, image 2 of 3 Dell Inspiron 13-7370 Fan Replacement: step 5, image 3 of 3
      • Lifting the fan, disconnect it from the laptop by grasping the connector (circled in red), and pulling out horizontally.
      • Do NOT pull the connecter upwards, as this may damage the socket you are pulling it out of.
      Ask FixBot
    6. Dell Inspiron 13-7370 Fan Replacement: step 6, image 1 of 1
      • Remove the fan from the device.
      Ask FixBot
Zayed Azam
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 31
All Time: 1,235
