Dell Inspiron 13-7359 Screen Replacement
    1. Dell Inspiron 13-7359 Screen Replacement, Battery: step 1, image 1 of 1
      • First flip over the laptop to expose the back panel
      • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
      Ask FixBot
    2. Dell Inspiron 13-7359 Screen Replacement: step 2, image 1 of 1
      • With a plastic spudger, carefully remove the back panel by prying each corner off individually
      • Slowly pick up the panel and set it aside
      Ask FixBot
    3. Dell Inspiron 13-7359 Screen Replacement: step 3, image 1 of 3 Dell Inspiron 13-7359 Screen Replacement: step 3, image 2 of 3 Dell Inspiron 13-7359 Screen Replacement: step 3, image 3 of 3
      • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
      Ask FixBot
    4. Dell Inspiron 13-7359 Screen Replacement: step 4, image 1 of 3 Dell Inspiron 13-7359 Screen Replacement: step 4, image 2 of 3 Dell Inspiron 13-7359 Screen Replacement: step 4, image 3 of 3
      • To remove the old battery, slightly lift the bottom edge of the battery with your hands
      • Now slowly pull the battery towards you to fully detach the battery
      Ask FixBot
    1. Dell Inspiron 13-7359 Screen Replacement, Hard Drive: step 5, image 1 of 1
      • Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
      Ask FixBot
    2. Dell Inspiron 13-7359 Screen Replacement: step 6, image 1 of 2 Dell Inspiron 13-7359 Screen Replacement: step 6, image 2 of 2
      • Lift and hold the hard drive in your left hand.
      • Use your right hand to grab hold of the black wire connector attached on the right of the hard drive.
      • Carefully pull the connector away from the hard drive to completely disconnect from the laptop.
      Ask FixBot
    1. Dell Inspiron 13-7359 Screen Replacement, Cooling Fan: step 7, image 1 of 2 Dell Inspiron 13-7359 Screen Replacement, Cooling Fan: step 7, image 2 of 2
      • Unscrew and remove the 2 of the 7mm Phillips head screws holding the cooling fan in place.
      Ask FixBot
    2. Dell Inspiron 13-7359 Screen Replacement: step 8, image 1 of 1
      • Hold the cooling fan with one hand.
      • With the other hand, grab hold of the part of the copper heat sink that is attached to the cooling fan.
      • Carefully pull the cooling fan away from the attached part so that it becomes fully disconnected.
      Ask FixBot
    1. Dell Inspiron 13-7359 Screen Replacement, Screen: step 9, image 1 of 1
      • Make sure that the Battery, Hard Drive, and Cooling Fan are safely removed.
      Ask FixBot
    2. Dell Inspiron 13-7359 Screen Replacement: step 10, image 1 of 2 Dell Inspiron 13-7359 Screen Replacement: step 10, image 2 of 2
      • Unplug antenna cables located at the top left corner.
      • Unplug daughter board located to the bottom left of the cooling fan.
      Ask FixBot
    3. Dell Inspiron 13-7359 Screen Replacement: step 11, image 1 of 2 Dell Inspiron 13-7359 Screen Replacement: step 11, image 2 of 2
      • Find the heat sink (copper colored metal).
      • Use Phillips 0 screwdriver to loosen the 3 of the 3mm Phillips head screws from the heat sink.
      • Remove the heat sink
      Ask FixBot
    4. Dell Inspiron 13-7359 Screen Replacement: step 12, image 1 of 3 Dell Inspiron 13-7359 Screen Replacement: step 12, image 2 of 3 Dell Inspiron 13-7359 Screen Replacement: step 12, image 3 of 3
      • Use Phillips 0 screwdriver to unscrew the 2 of the 3mm screws holding the LCD cable bracket in place.
      • Remove the LCD cable bracket.
      • Unplug LCD and touchscreen cables.
      Ask FixBot
    5. Dell Inspiron 13-7359 Screen Replacement: step 13, image 1 of 3 Dell Inspiron 13-7359 Screen Replacement: step 13, image 2 of 3 Dell Inspiron 13-7359 Screen Replacement: step 13, image 3 of 3
      • Use Phillips 0 screwdriver to unscrew and remove the 3 of the 7mm screws from the LCD display.
      • Open the laptop so that the screen and keyboard are face down on the desk.
      • Carefully disconnect the LCD display by lifting the screen upward and away from the bottom half of the laptop.
      Ask FixBot
    6. Dell Inspiron 13-7359 Screen Replacement: step 14, image 1 of 2 Dell Inspiron 13-7359 Screen Replacement: step 14, image 2 of 2
      • Using a plastic spudger carefully separate the casing of the screen.
      Ask FixBot
    7. Dell Inspiron 13-7359 Screen Replacement: step 15, image 1 of 3 Dell Inspiron 13-7359 Screen Replacement: step 15, image 2 of 3 Dell Inspiron 13-7359 Screen Replacement: step 15, image 3 of 3
      • Use the plastic spudger to disconnect the mini circuit board from the casing.
      • Disconnect the small wires connecting the screen to the casing.
      Ask FixBot
    8. Dell Inspiron 13-7359 Screen Replacement: step 16, image 1 of 2 Dell Inspiron 13-7359 Screen Replacement: step 16, image 2 of 2
      • Remove the loose wiring from the perimeter of the screen.
      • Gently separate the LCD screen from the laptop casing.
      Ask FixBot
7 other people completed this guide.
Austin Navarro
255 Reputation
1 Guide authored
Baylor, Team S1-G6, Johnson Spring 2018 Member of Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Members
60 Guides authored
1 Guide Comment
Hi, I was wondering if there's any possibility of cross compatibility between i7378 and i7359 from dell? My computer is the i7359 but I haven't been able to find a reasonably priced replacement display. Thank you very much! Also, I found this alternate guide suggesting that the screen can be replaced slightly more easily than the manual and this guide suggests, is this process feasible? https://www.insidemylaptop.com/replacing...
Ankita C - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 87
All Time: 6,324
